5 elements, 5 groups
Hibbs
R.I.P. Charlie
12:16 PM
Vancouver, BC
I am awaiting delivery of a Tokina made Vivitar that has 5 elements in 5 groups.
Could someone share with me what type of lens this may be? Is it a Heliar formula? Would this relatively low element count excel at low light?
Lastly, which sites are best for researching the various formulas and their history.
Thanks
Is this the lens you are interested in?
If you scroll down the page and look at the blue link under Lens Construction you will find the lens diagram. The page does not appear to categorize the lens formula.
Doing some quick searching, the 5 element heliar designs all use a 2-1-2 arrangement
The Schneider Retina Reflex Curtagon 35/2.8 was a 5/5 I believe. Later versions for other cameras were 6 elements. The Nikon series E 28/2.8 original Nikon Af-Nikkor 28/2.8 was also 5/5.
Not a 35mm format lens, but 6x9 to the equivalent FoV of 39-40mm.
The Fujinon has always appeared interesting to me because there aren't cemented groups, nor it's a 6 element design much more common in Double Gauss derivatives. In RFF there is this fantastic thread that focuses on such types of lenses developed towards faster variations: A Short History of Fast Normal Lenses
More or less Tessar based retrofocus wide angle SLR lens then, with the rear group separated. Quite similar to the first versions of that type like the Angénieux 35mm 2.5 but with fewer elements and no groups.
Fujifilm also has a range of 35mm SLR lenses that have no cemented groups in the design. Both in the M42 and X-Fujinon range. Sometimes its catalog info describes them as having groups but taking them apart shows that while close fitting that group can not be cemented, curvatures too different. Common types: reversed and straight Xenotar/Unilite designs like your example and the Unar type.
Even in the Fuji compact models with fixed lenses that trend is noticeable.
