Kai-san
Filmwaster
What camera is that?
It's a Wirgin Edinex from around 1946 - 47, first introduced in 1935. It came with a variety of lenses, this one has a Schneider-Kreuznach Xenar 1:2,8/50.
Edinex. A very compact device often forgotten.What camera is that?
When properly loaded, you will feel some tension rotating the winding knob (film advance) and the rewind knob will rotate in the opposite direction.On a bottom feeder Like a (sorry, bottom loader) an early Leica, how can you tell if the sprockets have engaged the sprocket holes?
You can see 'em.On a bottom feeder Like a (sorry, bottom loader) an early Leica, how can you tell if the sprockets have engaged the sprocket holes?
Don't forget the rangefinder needs calibrating, my friend!Sounds more like a problem with that cameras take up spool since I've almost never had that happen. I did lose several rolls with bottom feeders till I started a modified version of that - stick uncut leader into the take up spool, wrap it twice, begin inserting the take up spool into the camera, pull enough film out of the canister to slide back along the edge of the film path to where the can drops in and the slide it all down into place. Then put on the bottom plate with my third hand... 😈 Put a roll of Pan F into my Canon IId the other day like that in anticipation of testing it when I get a really sunny day off again.
Rigidity.I’ve heard a few reasons why bottom loading film cameras are better. I’ve heard:
1) it allows closer placement of the film plane to the lens elements for better optical performance.
2) It holds the film flatter
3) Stronger body
4) less chance of light leaks
What say you?
Made me laugh!Tom Abrahamsson told me he rewinded his Barnacks by spinning it over his head. I am sure he was kidding.
Needs a test roll to determine what it needs first. Only with data can you proceed. The lens, for example, was not hazy at all, when used on my digital M 240.Don't forget the rangefinder needs calibrating, my friend!
The 1930s Contax rangefinders were used for all that too - and had removable backs, for easy loading...As the owner of an M2 I concur.
Of course, Leica's were designed to perform well in many severely technical fields of photography like engineering, astronomy, scientific macro and micro photography, places where whatever extra precision a solid body might give to an optical system could actually be realized, but all of these potential advantages disappear the moment you use the camera hand-held.
