TenEleven
Also I think dexdog when he says this is a bit unfair (besides the low resolution) is that the order of lenses does a switcheroo.
My bet is:
1st set: Top one is J3+, Bottom Sonnar Krasnogorsk
2st set: Top Sonnar Krasnogorsk, Bottom J3+
3rd set: Top is J3+, Bottom SK
4th and final set: Top is J3+ again, Bottom SK
My approach was going, by the lens color temperature alone. The Jupiter3+ in my experience has a cooler color temperature than the Jena lenses which tend to render a bit warmer. I assume (hope) that white-balance was set to something fixed instead of just AWB because otherwise my argument is completely naught.
You can see the same thing in Brian's pictures by the way. Except of course the Nikkor comparison which is trickier because Nikkors also render quite cooly.
My bet is:
