Old light meter quandary?
wrs1145
A native Texan living far from home., but happy.
3:47 PM
Bundang, So. Korea
Does the vintage Gossen Luna Pro use: an adapter w/ 2 LR44 batteries, or 2 EPX625G batteries (w/ no adapter)?
Thanks,
Bill
If you can get the adapter that Gossen made that lowers the voltage of the silver oxide batteries to match that of the 1.35v Mercury batteries the meter was designed for, then use that. Do not use LR44 (Alkaline) batteries; you MUST use SR44 (Silver Oxide. Also S76 or 357 work too) batteries.
Alkalines do not keep a stable voltage; it constantly drops as the batteries are used. The Luna Pro does not have built in voltage compensation, so the batteries must deliver 1.35v each (total of 2.7v) at all times or the meter will not be accurate. For this reason, the EPX625G will not work on this meter. The starting voltage (1.5v) is too high and they will constantly drop as they are used, so the meter will never give consistent readings.
This is one of the reasons why I finally got my Sekonic L-308 that eats one AA, and takes a very long time to do so 😉
All the classic meters are very nice, don't get me wrong, but that one "just works" does incident, reflective and (should I ever get the desire) flash metering too for a decent price new and my pretty blue 60th anniversary model was even less used.
I had several meters converted and calibrated by Quality Light Metric in Hollywood but the owner retired a few years ago and I’m not aware of anyone repairing meters and converting them now.
Anyone know of a light meter repair and conversion service.
George at QLM rebuilt my Weston Ranger 9, Luna Pro, Weston Master V and 3 Leica MR meters. They all take modern batteries now with the exception of the Master V which is a selenium cell. In the Master V he re-magnetized the galvanometer, replaced the cell and the low/high range grid and calibrated it. The all work like new now.
Anyone else doing this? I have one more Ranger 9 I’d like to get calibrated.
Look up KANTO or C.R.I.S MR-9 adapters. I just bought two for my Gossen meter, and they cost me more than the meter did, but should be good for the life of the meter and more. There are also Wein cells, which are also acceptable but not as long lasting as the silver oxide batteries that the adapters use, so the cost adds up eventually.
I've used the MR-9 adapters with good results too, but now only in those cameras that take a PX-13/PX-625 original battery. My vintage meters turned over about a dozen or so years ago ... All my current meters use AAA, AA, or CR123 batteries.
G
A cheaper (and better) option IMHO is https://www.butkus.org/chinon/batt-adapt-us.pdf; Frans de Gruijter has been making these adapters for quite a while and while the document linked is from 2014 the prices are still the same -- I just received a BAT43 adapter a few weeks ago for €16. Works perfectly in my Leica CL.
Wow! to all this. Finally I have an explanation to why my three Gossen meters all give slightly different readings.
The adapters occasionally turn up on Ebay. I will be watching that site for some.
Many thanks to all who posted with explanations, especially (as always) Chris Crawford.
A happy end to my long story: I couldn't find any 356's in Korea, so I decided to purchase a couple of SR44's that were available and VIOLA!
they fit and work fine. Many thanks to the members who gave me advice.
I appreciate all the help,
Sincerely,
Bill
This will be rather like rubbing sawdust into an open wound - but if you had a Weston Master of any vintage as long as the cell is functioning and the thing works with reasonable accuracy, all these problems would vanish into the wind...
Of course the trick is in the "reasonable accuracy". My III, my two IVs, my three Vs and my four EuroMasters all read exactly spot on, that is half a stop under, which it seems is common with those ancient things. I do a quick mental adjustment based on the light conditions at the time, and Bob's my uncle on results with B&W or color neg.
Slides, well, my digitals have replaced this film, so it's not an issue. But the minus half stop works wonders in glary Aussie light.
