shawn
I think for most (all?) of them they really just changed the name and dropped the DG DN label. Other than the new silver color option. MPB usually has a nice selection of used L mount glass.
I don't know if the BF has it but on the fp L you can turn on magnification and the center portion is always magnified except with a half press of the shutter button. That bugged me at first but the logic of that with an adapted lens actually makes a lot of sense.You can always see the edges of the framing with the middle being zoomed in. Focus, then half press, final compose and shoot. Once you let go of the shutter release the center is zoomed again. Saves a button press every time you want to focus and is quicker once you get used to that logic.The screen is a weak spot, so seeing to manually focus under adverse conditions is a challenge. Autofocus definitely eases the workload there, where manual focus needs one hand on the lens, one hand on the shutter, and a third to touch the screen for magnification. (It took me a while to figure out how to make the magnification 'hold' instead of timing out after two seconds.) Having autofocus cuts the number of hands needed in half.
Success, maybe.
Great find!Interesting. I looked, but couldn't see any setting for that, and there aren't a lot of places for settings to hide on this camera. But that got me looking at other possibilities, and sure enough, clicking the centre of the wheel while the shutter button is half-pressed will magnify the screen. So that's easier, if the centre is what I want magnified, and it usually is.
The 45? I wanted the newest version because the person at Sigma USA I spoke with implied that there might be minor product improvements over the original.Why do you need a revised one Ken?
The only other change to the 45mm (beyond the font) was that it now works with the magnetic lens cap, which made it slightly heavier.The 45? I wanted the newest version because the person at Sigma USA I spoke with implied that there might be minor product improvements over the original.
Is it possible to tell the difference between 4k and 6k?Shoots 6k video but no mic jack!
That is going to depend upon how you use it. If you have a display that can handle the higher resolution then yes. The extra resolution also can be used to let you crop video a bit and still end up with full 4k video.Is it possible to tell the difference between 4k and 6k?
The magnetic cap has value to me, too. I just prefer to have the current version.The only other change to the 45mm (beyond the font) was that it now works with the magnetic lens cap, which made it slightly heavier.
Optically Sigma didn't change anything. (Sigma confirmed this)
This lens just came out -BH lists it as "New Item - Coming Soon".there are no firmware updates shown on the manufacturer’s website
I purchased mine from TTArtisan on Amazon.This lens just came out -BH lists it as "New Item - Coming Soon".
That is nice on the BF. That is how my Panasonic L mount cameras work but on the fp L setting the lens to A just changes the aperture control to a dial on the camera instead of putting it into Program mode.My Sigma 45 arrived, but I haven’t had a chance to get out with it due to weather and family commitments. I’ve found if I leave the BF on auto aperture I can override to aperture priority on demand using the lens aperture ring without menu diving. Camera set to auto shutter speed and auto ISO with the lens aperture ring parked in A = drunk mode, take control of aperture using the lens ring with no other changes = aperture priority. EC is always available on shutter half press, and I tend to leave the back wheel parked on format.
I also ordered a used Panny 20-60 to use as a family and vacation lens, it’s inexpensive, smallish and seems to be well regarded. Between the 20-60 and 45 I should be good for vacation.
I thought I saw comments about the 18-40 that dissuaded me. Should I reconsider?That is nice on the BF. That is how my Panasonic L mount cameras work but on the fp L setting the lens to A just changes the aperture control to a dial on the camera instead of putting it into Program mode.
The 20-60 is supposed to be a good lens but for a tiny walk around zoom I think I would go with the 18-40.
