Slumgullion
Thanks for input, Erik! Developing temps were probably following manufacturer's recommendations. I say probably, because it was nearly 20 years ago...and I was often drinking while developing 😅. I am sure that my developer temps were correct, though. The apartment I lived in had air conditioning, so I doubt that the rest of the chem was ever too hot (but I probably didn't ever check). The thing is, I had scanned these negatives at various points in the past and the issue wasn't present 10-ish years ago (the last time I scanned them). And none of the other black and white film I have from that era shows this kind of deterioration (it's only the Neopan 400).How do you develope your negatives? It seems that the emulsion layer has cracked. Perhaps the developing procedure was too hot or the film was stored too warm. The effect is called "reticulation". I have this problem sometimes when using Tmax400. I always try to keep the temperature of the different baths exactly at 20 degrees C.
Slumgullion
Well, on further examination, it does appear in my scans from 10 years ago. It's just that I was using a flatbed scanner at that time and the sharpness of 35mm scans was very poor and thus the reticulation was hard to see. With 'DSLR' scanning the apparent sharpness and resolution is much better and so the reticulation is more evident. Perhaps Fuji Neopan 400 was just more susceptible to temperature fluctuations than other films. Thanks, Erik! Problem solved.
Tuna
Fotoğrafçı
Tuna
Fotoğrafçı
mrtoml
Mancunian
Brambling
feeling
Brambling
atmosphereConnemara, Ireland. Shen Hao HZX45 field camera, Rodenstock APO Sironar N 150mm lens. Probably FP4.
mrtoml
Mancunian
The land around Connemara is very wet and often referred to as 'the bog' by locals. So when the temperature rises there is often some mist even later in the day than one might expect. It makes for good landscape photographs when combined with the hills and the sense of desolation.atmosphere
Brambling
me and the wagtail (Motacilla flava) meet the dawn in the fog - curious bird - probably always wanted to learn how to take pictures, but cowardly - barely visible in the photo)
Zorkiy 3m, JUPITER-9 85MM F2, Svema DS 100, 2016
steppe mound - I was taking pictures, and I was thinking about the history of this mound, I was making up a story for it like the ancient Egyptian pyramids)))
evening fog - then dew fell - got my feet wet - came into the house, drank hot tea, read a book - 10 years ago it was a beautiful wild place - no mobile phone service, no internet),
Zorkiy 3m, Industar 26m, Svema DS 100, exposed 2016
mrtoml
Mancunian
Erik van Straten
