0.136330222mm reduction in shim required to bring the lens in agreement assuming a 10cm error at 1.5m
I use the equation for focal length, plug in the actual focus and the distance as measured by the RF, compute the difference.
1/f=1/d+1/b
1/b=(1/f)-(1/d)
b=1/((1/f)-(1/d))
where f is 51.6mm, and d is the distance. Solve for b, back focus. I have this in Excel.
Good to know how to calculate this though for me its a bit academic - without a proper, accurate Engineer's micrometer I am reduced to trial and error or rather lap and test.
🙂 But as it happens it is still useful and heartening as it confirms that less lapping is needed than I thought might be. As it also happens, I also have another project on which I can try this once again (having done it a few times before - with success but purely by trial and error.
I recently bought a fairly mid-range lens adapter for Nikon F to Leica M mount. (This will be used only with a mirrorless camera, not a rangefinder one of course as there is no rangefinder coupling). When I used it, it was clear that I could not reach infinity with any lens I mounted on it.
These adapters are simply built with essentially three parts - the base plate which has the M mount, the mid-section / main body/ spacer and the top plate which has the Nikon lens mount. It's a matter of removing the top / M mount plate (undoing 5 screws) and performing the lapping / testing procedure on the top of the main body till it's back within spec. This sort if issue very occasionally happens with adapters unless you by a top brand one - though in my experience, mostly the discrepancy is small enough to be ignored for practical purposes. No great risk is involved as it's not an expensive adapter (and I have already replaced it anyway) but it's still nice to be able to use it as backup if needed.
When I measured mine (using a simple vernier caliper) it looked as if the deviation from what is required is slightly over 0.1 mm. In other words similar to the 0.136330222mm reduction you mentioned in your example.
For anyone interested in performing this type of operation themself if they are stuck with a "bodgy" adapter, I calculated the required alteration to the adapter by using tables of correct lens flange distances (readily available online) to calculate how thick the adapter
should be by subtracting the correct M mount flange distance from the correct F mount flange distance. This gave me the "target" to work to when performing my "surgery". I then measured the
actual thickness of the adapter from flange to flange and discovered, as noted above it was a little over 0.1mm out of tolerance - which is the best accuracy I can reach with my relatively simple measuring tools.
BTW lapping around 0.1mm by hand is still a substantial amount of work to perform especially considering the accuracy
required and constant checking therefore needed as you perform the work.
