HELP with F.E.D camera versions please
yardbent1941
10:08 AM
Scotland
I have a FED 4(b)
and am considering a FED 3...but
with my limited knowledge gained from searching the internet - I'm a bit confused..🙁
so far I believe........
FED 3(a) has a film knob, strap lugs and a stepped top-plate
FED 3(b) has a film advance lever, no lugs and a flat top-plate
so what is this version....?
flat top-plate, film advance lever and strap lugs
many thanks
Jean-Loup Princelle in his pretty definitive guide to Soviet cameras (worth buying, it is amazing) notes two types of 3b but only varying because of a slight improvement on winding mechanism. Nothing about lugs however; so I also feel it is a later addition. People did it to Leica IIs so why not Feds.
There is a less common version of the Fed 4 with a winding knob too. (Very weird aesthetics...)
Fed 4a, it seemed to get a lot from the FED 3a including the lugs and then added the meter. The lugs were then again lost with the 4b which had a lever wind. It really feels like there were many parallel developments all happening at the same time and no one though to coordinate.
According to Princelle
FED-3 type a 1961-63 (classic wind)
FED-3 L 1963-69 (3a with Industar-61)
FED-3 type b 1963-1976 (wind lever, two variants based on wind lever mechanism))
FED-3 L/D 1977-1980 (3b with Industar-61L)
FED-4 type a 1964-1971 (meter, classic wind, lugs)
FED-4 type b 1969-1976 (meter, lever wind, no lugs)
I think there was a lot of stock clearance in overlapping years.
For those that don't know it, this is the book:
It can be had new quite cheaply from the author if you bump into him at camera fairs, and very expensively on the second had book market. He tends to wear a kilt and play the bagpipes very loudly so he is easy to recognise.
Princelle‘s book is great but nowadays covers only about 2/3 of all the soviet cameras. There are also good online resources like sovietcams and ussrphoto.
The strap lugs are a nice feature on that Fed. Only early soviet cameras had strap lugs, later you had to use the ever ready case with it’s own strap.
