Will the long-anticipated Leica M11-V with built-in EVF arrive in 2025? Probably, but it’s taking longer than expected and rumors are still flying!
By Jason Schneider
Beginning in February 2025 and continuing into March, Leica Rumors, Red Dot Forum and other unofficial Leica-centric sites began publishing enticing stories, and even photos of putative prototypes, of a rumored new “Leica M11-V” with a built-in “EVF.” This is no conventional EVF like a shoe-mount Leica Visoflex 2, but an electronic or hybrid electronic version of the classic M-series multi-frame-line, opto-mechanical range/viewfinder that debited on the Leica M3 of 1954, but of course with three pairs of frame lines covering focal lengths from 28mm to 135mm. The “internal sources” that provided the info and Images referred to the camera as the “Leica M-V,” but it’s fairly certain that it will be called the Leica M11-V in line with previous iterations such as the M11-P, which provided the basis for the new model. Since the latest beta version of the Leica Fotos app already contains references to the Leica M11-V, most writers assumed the new model would arrive in a few weeks at most. However more than two months have elapsed since the initial reports and that hasn’t happened yet. Most writers are now expecting it to arrive later this year, in late summer or early fall.
Early mockup of "Leica M EVF" camera that resembles rumored Leica M11-V. Note built-in flash which may or may not be included.
Leica Rumors published some “leaked pictures” from a Leica survey that includes one with an EVF, and the M11-V will reportedly have a clean flat top plate and no ISO dial to make room for the EVF. There will be no Leica M12 this year; possibly that will have to wait until 2027. Does this mean that the two models will have different iterations of the built-in EVF? It’s entirely possible. Some writers have described the Leica M11-V’s EVF as “similar to the one in the Leica Q3 or SL3,” but the consensus is that it will have the same 60MP BSI CMOS sensor as the M11 and include features like USB-C, internal storage, and improved Live View. The new body may be slimmed down or reworked, possibly without the traditional ISO dial, and it’s expected to support closer focusing with new M lenses.
Here are some additional details on the rumored specs of Leica M11-V:
Possible Specifications (Not confirmed!):
Sensor: Full frame 60MP BSI CMOS sensor (same as M11)
Viewfinder: Built-in EVF (like Q3 or SL3 in terms of quality)
Optical Rangefinder: Likely no optical rangefinder
Connectivity: USB-C, internal storage (like the M11)
Live View: Improved Live View performance
Focusing: Closer focusing support with new M lenses
Body: Slimmed-down or reworked body without the ISO dial
Other: TheLeica M11-V is rumored to have a clean top plate and no ISO dial, potentially due to space needed for the EVF.
Sneak pictures of the rumored EVF showing focusing aids and finder frame lines. Image courtesy of Leica Rumors
Leica M11-V Q &A: Here’s what the experts told us:
  • Q. Will the frame lines in the new Leica M11-V move in and out as you focus to correct for the narrowing of angular coverage at closer focusing distances?
  • A. No, the frame lines in the rumored Leica M11-V are not expected to move in and out as you focus to correct for the narrowing of angular coverage at closer focusing distances. This is a common feature in Electronic Viewfinders (EVFs) where the frame lines adjust digitally to accurately represent the actual capture area at different focus distances
  • However, the Leica M line, including the M11, utilizes a different system for parallax correction, which compensates for the slight displacement between the viewfinder and the lens, especially at close focus distances. This parallax correction mechanism, which may cause the frame lines to shift slightly within the viewfinder, is a separate function from the focus-based frame line changes that would occur in a traditional rangefinder or the digital adjustment possible with an EVF.
  • The M11-V is anticipated to integrate a built-in EVF, and while the EVF offers the advantage of showing you exactly what the sensor sees, eliminating parallax issues inherent to rangefinders, it's not expected to replicate the physical frame line movement of the rangefinder system. Instead, the EVF display would provide a live preview of the image, including framing, focus, and depth of field, simplifying composition and eliminating the need for manual parallax compensation.
Q. Will the frame lines or the rangefinder patch in the new Leica M11-V be illuminated so they are more visible in very low light?
According to Leica Rumors, this image shows frame lines and digital (?) focusing patch likely to appear in Leica M11-V. Note ISO readout.
A. Given the rumors about the Leica M11-V featuring a built-in Electronic Viewfinder (EVF), the concept of illuminated frame lines or rangefinder patch within the traditional optical rangefinder becomes less relevant.
Here's why:
  • EVF functionality: The primary function of an EVF is to display a real-time, digital representation of the scene as captured by the sensor. This display itself is inherently illuminated, so the issue of seeing the frame lines or the rangefinder patch in low light, which is pertinent to traditional rangefinders, is eliminated. You see the image projected directly into the EVF, making framing and focusing easy regardless of ambient light.
  • No traditional rangefinder: The M11-V is rumored to have a built-in EVF and potentially lack the traditional optical rangefinder. Therefore, the separate issue of rangefinder patch visibility in low light, which can be challenging in traditional M cameras, is unlikely to be a concern with the M11-V's EVF.
Here's why:
In short, the M11-V, with its rumored EVF, will offer a modern shooting experience where the viewfinder display is always illuminated and provides a clear preview of the scene in all lighting conditions. You won't need to worry about the visibility of frame lines or a rangefinder patch as you would with a traditional optical rangefinder.
Back view of prototype Leica M11-V shows flat top, upgraded LCD on back, simplified controls.
One long time Leica fan is hoping the V in M11-V stands for VALUE and predicts a substantially lower retail price thanks to production savings from the EVF viewfinder compared to the optical rangefinder viewfinder. Hope springs eternal, but as those irreverent Brits would say, “Not bloody likely, mate .” Will the value of Leica Ms with traditional optical-mechanical range/viewfinders skyrocket in what looks like the coming era of the "EVF Leica M?" Probably, and Leica could always offer special edition all-mechanical Leica M's at (you guessed it) extra cost!
Looking at the front of the camera in the first picture shows something round at the top near the speed dial. Could this be something akin to what’s in phones and just used for the viewfinder image?
I don't recall what it's used for, but it's been a feature of all digital M cameras, from the M8 onwards.
There may be other ways to simulate the effect of frame lines with a conventional EVF.
i could not be LESS interested in an EVF M camera as it is being described. an EVF in any form is so very un-M-like that they break my heart a little bit whenever i see one.
frankly, i'm not at all interested in any M11. my M10-D is almost certainly the last new digital M that i will ever buy. it simply cannot be improved upon imho.
years ago Fuji struck a dagger blow into Leica with the hybrid viewfinder in the X100 and later the X-Pro cameras. THIS is something that Leica should have come up with. incorporating this would make for a very desirable M camera but German pride would never allow this innovation to be copied.
Never say never…
Are you going to write a manifesto about it like you did for the M8?
That might have been said when rangefinders were being considered as a part of the body.
a long memory, you have... no, i have said my piece and i am at peace. if this comment stokes the fanboys, so be it.
i see no reason laugh! RFF has been and still is a great resource. as we say in Tiny, Texas, "much obliged!"
Unless Leica can come up with an innovative manual focus assist, focusing an EVF M would be inherently slower than with a rangefinder. My eyes aren't quite so good as to be able to focus with the SL2S manually without punching in, so I see no reason why it would be any faster on an EVF M. Nevertheless, the prospect of an EVF M is quite exciting, as it will be fascinating to see what Leica does.
Not for me.
I am hoping Leica can make it work like the Nikon Zf and Z8 where eye recognition works in manual focus and automatically zooms to the eye.
If enough people are prepared to pay a sufficiently high price for an M mount EVF camera with the form factor of an M then perhaps Leica will make it.
As far as I am concerned though, manual focus, the M mount and the flange to sensor distance make such a camera pretty pointless. Assuming it to be expensive (Leica don't really do budget proced cameras) it will be a costly way of obtaining a camera with litytle versatility beyond taking adapted LTM and M lenses. There are much higher specified, far more versatile cameras alteady available, and they will be better value should such a camerax be produced.
Now an M form factor L mount camera might be a different proposition altogether.
Not for me.
This would be an essential element I think. Plus, an evf ‘should’ be much less expensive than a true rangefinder.
On the other hand, the window viewfinder is an important element of rangefinder photography apart from the rf itself. Whilst I didn’t get on with the Fuji x-pro’s and went back to M, that was down to the manual focus not being well supported. The window was great.
An EVF is lighter than a rangefinder too.
I should have thought that it would make sense to draw on Fujifilm's experience of having a hybrid optical / electronic finder on some of their line-up of cameras. Thus, giving the best of both worlds to users. Knowing Leica I am sure they will find a way to over-engineer it and charge 10 times the cost for doing so. 🤣🤣🤣
They could increase the magnification over the SL2S. My S1R with DK-17M is easy to MF fast and without need of any zoom or focus peaking. Going from .78x to about .94x is a pretty big difference on this.
