Lens carrying system
ped
Small brown dog
4:59 AM
England
I was selecting some lenses for a trip and wondering how best to store them in my bag. I got to thinking that a system like the (bad) mockup below would be a really nice way to keep them from banging about and make them easily accessible. Basically, three rear lens caps screwed/glued to a board. Voila - your lenses can now slide into a photo compartment.
Thoughts? done before? I'm thinking of using it for my Paxette lenses (35/50/90/135mm)
Cheers
ped
I'd be bothered by all the wasted space between and around the lenses, and the fact that the compartment would need to be big enough to accommodate your largest lens sideways.
Leica used to make back-to-back m-mount lens caps so you could stack a couple of lenses together. So if you could rig up something like this for LTM then you yo'd be able to leave the 50 on the camera, stack the 35 and 90 back-to-back and put them and the 135 into two thinner compartments next to each other.
My dad used to have a Nikon bag with three or four bayonet mounts secured to the floor of the bag, along with space for a Nikon F with lens mounted. That was back in the 1970's. It was his favorite bag, even though it was a bit bulky and certainly not hip-hugging.
Reminds me of the Leica LTM lens turret:
  • Like
Reactions: ped
Two Amazon LTM rear lens caps and a dab of JB-Weld and you could make your own.
This is a good idea. I had the one that Leica used to make; being only plastic, they wear out and get loose, just like any other. Replacing them from time to time with ones from Amazon or elsewhere is good insurance against dropping a lens on the pavement.
Experience has taught me that it's a very, very rare occasion that I'll use more than two lenses while out photographing. If you have an old fashioned lens case that can be attached to your camera strap, the issue is solved. Otherwise, I keep the other lens in my backpack/whatever bag I'm using.
My system is to use small foam bags made expressly for this purpose in differarent lengts. Works great!
This would be good for me. Right now I am literally using small cloths in my bag in the same way. Perhaps you could share the source of the little foam bags?
I looked at that option but most of the lens bags/tubes seemed to be for DSLR sized lenses. In the past I'veused iPod socks (remember those?) which worked really well, actually.
Hey, guess what I just saw on eBay:
