Pre-war biogon 35mm f2.8 vs Planar 35mm f3.5
stephen_lumsden
12:56 PM
Harrogate
I have 2 Contax ii cameras and a lot of lenses with them. I have a J-12 which is good, but sometimes, I think it could be sharper. I was thinking about getting a Nikkor 35mm f3.5 but want to be able to focus up close accurately, so it comes down to the two above (the post was biogon seems too expensive). I am looking at them from 2 reputable vendors. The Biogon is £349 and the Planar £325. I never plan on getting a Contax iia so do not mind the bulge at the rear of the Biogon btw. Both come with pouches or cases.
The Nikkor 3.5cm F3.5 will be off, it is possible to slightly reduce the Shim for sharper focus- but not for the full range. Chances are the DOF will cover the error on film.
I've also noted more variation in the Nikkor 3.5cm F3.5: I had one in LTM that was soft, later picked up a 1949 version that "blew me away" as it was so good. The Nikkor 3.5cm F2.5 - I've noted less sample-to-sample deviation, and did shim one for Contax for an RFF member. Optimized for close-up/wide-open, stop down for infinity.
J-12: a lot of sample-to-sample variation, with those by KMZ being the best.
The Zeiss lenses: as you note, more expensive, but a safe bet. I have the Biogon "T", very good. I do not have the Planar. It is not as common as the Biogon, surprised it is lesss. Check relative condition of each.
thx Brian. I would be tempted to get a Nikkor, but that would only tempt me to get a Nikon S2 or S3 down the road. I am sticking with Contax or Kiev. I have a Voightlander 25mm, for Nikon S, which suffices for landscapes. I did shoot my wife close up once and noticed she was sharp but not overly so, most likely at f4 the differences may be slight but noticeable.
This is what RFF member TenEleven said about the Planar
Post-war Carl Zeiss (Opton) Planar 35/3.5 - Rangefinder Coupled - Mounts on IIa - (4 groups / 5 elements)
All coated. Rare. Brass finish. Made as a cheaper alternative to the post-war Biogon. Planar design. It offers a very punchy, vivid color reproduction that is different from almost all the other lenses in Zeiss line-up, making it the odd-man-out. The sharpness well into the corners is excellent from wide open. Perhaps not on the Biogon's level in the picture-center, however readily beating it in the corners at open apertures. There is a lot more vignetting than its more expensive brother, but I have not really managed to get this lens to produce any flare. Distortion is invisible.
A quick pic of my dining room (yeah, I need to dust the table). Planar about 2 meters wide open, point of focus is second candlestick from the left. Straight outta camera jpeg, probably a bit overexposed but did not tweak it. This pic does not show any vignetting, but I agree with TenEleven that it will vignette more than the Biogons will, I think it shows up more in bright light. Purposely framed it this way to get the bright light streaming in from the right. Should be able to see a higher resolution image by clicking on pic and using RFF as password.
Vignetting at f3.5 does not look great. Or is that the sensor effect. How's the Biogon wide open?. Also I may be tempted by the half stop speed hike. Does the lack of coating on pre war lenses affect the sharpness much in comparison with post war coated ones?
I dont think the vignetting it is a sensor effect, the Planar does not have a rear lens group that extends deep into the camera body close to the sensor. The Biogon will show sensor effects on both Sony a7III and to a lesser extent on a Nikon Z6, which manifests as smeared corners. The Z6 is better in this respect, but not immune. The lack of coating on the pre-war Biogon will not affect sharpness all that much compared to the post-war version, but will exhibit less contrast and would be more prone to flare, as expected. I may take a pre-war Biogon and Planar out today to shoot side by side.
Planar on left, Biogon on right. You can see that the rear lens group of the Planar is deeply recessed inside the fixture. I used a set of calipers to estimate how far the rear lens group (not the lens fixture) of Planar projects out from the base of the lens mount, it is about 2mm.
Shooting a blue sky is a great way to tell when sensor needs dust removal! Also, vignetting of Planar appears to be greater on the Z6 than the a7III
Biogon f8
Planar f8
I've used the post-war Biogon quite a bit with exceptional results at all aperture settings. I obtained a planar with some other Contax stuff I bought a few years ago and sold it (which I illogically sort of regret since I own a perfect Biogon!). I never used the Planar, but I can profess it was beautifully crafted like all Zeiss rangefinder lenses I've seen from the era in which it came. Some say it was made as the "economy" 3.5cm focal length option by Zeiss, i.e., with less specification than the Biogon and less expensive. Perhaps, but that concept of "economy" would raise the bar!
