Macro options for FED or Zorki?
Honestly I would just completely steer clear of the FED 1 altogether. If you're set on a Soviet rangefinder, the FED 3 and Zorki 4 are far better cameras
I would hard disagree with this. The Zorki 4 and 4K is the single most problematic camera of the whole FED/Zorki line - I've seen so many of them with jammed shutters. Something in the way the slow speed mechanism was introduced makes them a lot more unreliable than the other reasonably priced models with a slow speed train (the FEDs 3 through 5). I've heard the slow speed train in the Zorki 3 models are even more problematic, but those are usually much more expensive anyway.
If someone wants a Soviet rangefinder with a combined VF/RF, I always point them at the FED 2, Zorki 5, and Zorki 6. Those things are basically bulletproof.
If you want to do a bit better than the FED-1, there are several cameras that you can purchase an accessory for called an Auto-Up which clamps to the front of the normal taking lens (usually a 5cm/50mm) and covers the viewfinder and rangefinder windows with a prism to change the field of view for close-up photos.
These are a lot easier to use than a NOOKY-HEESUN on the Leica.
I forgot to mention these. The Auto Up can actually be used on a lot of LTM cameras - they're specific to the lens, not the body. I use mine on a Leica IIIg from time-to-time, but they fit anything of similar size (Canons, Leicas, Niccas, Leotaxes, FEDs and Zorkis). You do need a larger Auto Up for bigger bodies like the Canon 7, though.
Anyway, they're much faster/easier to mount than a NOOKY, I'll give you that. But they're nothing like as easy to use.
The NOOKY has a moving cropping frame in front of the Leica's viewfinder, reducing the view from above and the side as the NOOKY is focused, meaning the framing is pretty much bang-on at all distances. On the other hand, the Auto-Up relies on a combination of a little nub, guesswork, hopes and dreams:
Here's what that looks like through the IIIg's finder:
At least with a IIIg, you have a wider view and some framelines that kinda-sorta help you frame. On everything else, it's basically guesswork. As a result, the Auto-Up is very much a "close focus of last resort" option for me rather than a reliable tool.
I‘m not sure, the Zorki 4 is probably the best bang for the buck. The slow speed mechanism definitely adds complications to the concept of the shutter but strangely, the mass produced Zorki 4s seem to be pretty reliable.
I have both a Contatest for Zeiss Contax IIa/IIIa cameras and the Nikon version of this for my Nikon SP and 5 cm f/1.4 which are similar to the Auto Up. I haven't used them a lot but I didn't find the framing to be that far off. Sharpness was better than I expected since I think both Zeiss and Nikon made the screw in close up lenses for their specific lenses. I have seen results from generic close up lenses that were pretty bad.
On paper, I almost agree with you: very large finder, full range of speeds from 1 second to 1/1000, removable back for easy loading, diopter on the viewfinder, and as long as you get an earlier one, strap lugs.
However... the knob wind is not very accessible, the slow speeds almost always cause problems, the rangefinder base length is pretty low, and the shutter speeds are printed rather than engraved.
I haven't touched my Zorki 4 in years; the 5 is smaller, more reliable, more accurate, and a lot more pleasant to use. Ditto for the FED 2... but my FED 2 is a late one and doesn't have strap lugs, and I hate messing around with half cases!
I've had three Zorki 4s, and one Zorki 4K, and never had mechanical issues with any of them, except the self timer on the 4K would not function. Why three if they work so well? The first was stolen, the second I sold, and later regretted this, so bought a 3rd. The 4K was purchased just to see what it was like, but the lack of strap lugs was a deal breaker. Still, except in viewfinder size and brightness, the Fed 3 bests it in most respects. Maybe some of the later Zorki 4s are not so good, they produced them for a long time. All three of mine have been 1960s era.
The printed shutter speeds started on the 4K, though late 4's had the name printed, but speeds were still engraved like on my '68 model.
PF
Here's the top of my 1970 Zorki 4, which predates the 4K by two years:
Predictably, you can barely see any of the slow speeds. Almost entirely faded and worn away.
This one was given to me for free some years ago because the shutter had totally jammed. Relatively easy fix, but playing with it now for the first time in ages, turning the winding knob feels oddly heavy. The small amount of purchase you can get on the knob thanks to the large shoulder on the top plate next to it doesn't help matters!
I should really clean it up a bit and run some film through it, but it's easily the least appealing camera on the shelf. I will never understand why these damn things are so popular.
For a long time, the Zorki 4 was, undeniably, the best deal one could get for a rangefinder camera. These days I don't think that's still the case, as prices go up, and cameras in good condition become harder to find. Plus, in the West the Zorki was one of the few Eastern Bloc cameras that sold in decent numbers, so was one of the few Soviet rangefinders that could be found relatively easily from local sellers. The Feds and Kievs were not so common to find before the 1990s, and particularly before online commerce was a thing. The Zorki 4 already had a reputation and a following before the "fad" for Soviet rangefinders kicked off in the west with the rise of selling over the internet.
That said, there's inherent qualities in the design that are appealing. It has the largest and brightest combined VF/RF of all the common Soviet cameras, and indeed it's a good one for any RF of that era. It's solidly constructed, and fairly straightforward to use (doesn't need any special treatment of the film prior to loading, etc. unlike Leicas and most of their closer Japanese copies). Get one made before they started pinching pennies (ie. look for one with strap lugs) and the fit and finish is usually pretty good too. Sure it has its ergonomic faults, but so do the Kievs and many others.
Just looked at mine again and it turns out it's a '64 model (not a '68) with matching J-8 in chrome, so the printing of the name on the front started much earlier than I thought, but I still have the engraved shutter speeds. It's a non-export model. I don't have any issues with winding as I use the finger drag method instead of the pinched fingers.
PF
Got a FED-1 (type 11-b) from Ukraine in early December. Enjoying it quite a bit. A Leitz / Leica Visoflex 1 just showed up nearby. Anyone have any experience using this on a FED-1? Here is the description: "1950's E. Leitz Wetzlar / Leica Visoflex 1 with 45-degree "PEGOO" viewfinder for M39 screw mount. Excellent cosmetic condition except some very light dust inside. Eye ring turns very smoothly. I am not sure if this is an OZYXO or an OZUPO -- it was used with a Leica 1F camera. Comes with a Novoflex Macro Rail / Bellows, also in great condition."
As long as your FED's flange-to-film distance is standardised, it should work fine.
There are a pair of screws towards the back of the unit - one on each side - that loosen the lens mount. If you find it doesn't screw in perfectly upright on the FED, you can loosen those, rotate the unit slightly to get it lined up correctly, and then tighten them back down.
The biggest issue will be lifting the mirror before you trip the shutter. There was an accessory for making this easier - the OZXVO - but they're not cheap, not common, and won't fit on the FED. Leitz also produced double cable releases that would both lift the mirror and trip the shutter in one press, but you've got to make sure you get the right one; most have the Leitz/early Nikon female thread on both ends. You'll need a slightly later one with the male threaded release on the camera end - but it still needs a female release on the end that fits to the Visoflex unit.
That said, you can always just use two separate cable releases if you're working on a tripod (which you likely will be anyway), or if you're particularly dextrous, you can always do it by hand...
It feels more than a bit ridiculous, but it does work.
The NOOKY and Auto Up may not work with a Fed-1. The Focoslide should work, but I still think that requires a body with Leica std film-flange distance.
I have yet to get in my hands a Fed-1 with proper Leica standard film-to-flange distance. Mine have all been "non standard". I only kept the NKVD because it had its matching non std lens. Leica std Fed-1 might exist...but probably the result of luck and variability to get one. Film is forgiving though -- right?
The Auto-Up will - as long as you have the right lens (Canon's 50mm f/1.9 or f/1.8 lenses will work; not sure about the faster ones). It's position-agnostic - if the FED's lens mount is slightly crooked compared to a Leica, it won't make any difference.
The NOOKY, however, won't. It won't line up correctly.
The Focoslide is by far the better (albeit slower) option here. But, as you pointed out, it's very dependent on having a FED with a post-war standardised lens flange-to-film distance. Pre-war ones will be all over the shop.
I gave up with ltm cameras and very close up stuff. Nowadays I use a 60mm Macro Elmarit R and anything that will fit on the back of it, currently a Nex 6 having sold the old SL.
Call me a wimp but it works!
this thread reminded me of the time when there was a Zorki 1 on ebay for 15€ that came with a KMZ macro lens. I turned it down because it was a macro lens. Should have bought 🫣
