Yashica 635 Copal MXV Shutter
Bobwill
4:22 PM
Midlands UK
I have just purchased a Yashica 635 TLR but it has an issue with the self timer mechanism. It is working of sorts but not as intended. The actuation lever moves only a short distance so that cocking the shutter and and the self timer (which only moves partway) then firing the shutter the maximum delay is about 3 seconds then the shutter fires. It all appears to function correctly except the time delay is shorter than it should be. Now I have not dismantled anything as yet but looking into the slot that the timer actuation lever moves in it has a steel part stopping it's travel. I have found on the Internet some images of this type of mechanism dismantled. From these images I have identified the part. Can anyone help with function of this part and why it would interfere with the timer actuation lever. The part is arrowed in the image.2323.jpg
Identification of the Arrowed Component​
Component is (functional):
Self-timer blocking / release slide
(often also called the self-timer interlock bar or timer release slide)
This is not part of the shutter timing train itself.
It is part of the interlock between the self-timer and the shutter
What This Part Does (Critical)
This sliding bar has three jobs:
When the self-timer is set
It moves into the shutter release path
It blocks the normal shutter release lever
It forces the shutter to be fired only by the self-timer
During the self-timer countdown
It is held under spring tension
It slides gradually under control of the timer train
At the very end of the countdown
It moves just far enough to trip the shutter release
Immediately after firing, it must:
Snap fully back to its rest position
Completely clear the shutter release path
If it does not return 100%, the shutter will not fire normally.
Don't know where you got that description from but it's mostly totally incorrect.
The part you arrowed is there to PREVENT the self timer from being set if the shutter is in M mode. The self timer should ONLY be used with the shutter in X mode otherwise the self timer can be damaged. If you move the X/M switch you will see the part gets moved upwards into the path of the self timer lever to STOP the self timer being used. Unfortunately, few people bother to read the manual and just force the self timer past the lock resulting in, usually, permanent damage. Yours looks undamaged (so far) so try and keep it that way.
EDIT: Just realised the picture you posted isn't yours so yours may already be damaged.
Here's one that's been forced.View attachment 4883619
monopix, thank you for your reply I am still in the collecting information mode and have not made any attempts to fix. I have this Yashica 635 it has a broken X M switch (It has no MX switch. The timer actuator is blocked by this part. My inquiry was to establish what the function this part is. The answer I posted was obtained by an enquiry to ChatGPT, from your reply clearly it was wrong. What you have described for this part makes perfect sense and also gives the answer to another question, in what position did my MX switch get broken.
Sometimes the M/X lever gets removed to stop the user selecting the M mode. Maybe that was done but the switch has moved on its own. In the picture you can see the lever is riveted together. The rivets will have been removed or have broken and the other half of the lever will still be there. If you use a small screwdriver or similar through the slot where the lever normally is, you should be able to push the remaining part of the lever over to the left and into the X position. That's probably all that's required.
Yes I can see the remains. Comparing it to your image you are correct rivets broken. I will give your solution a try thank you.
My word -- you went to ChatGPT for this? I would avoid at all costs anything AI tells you unless a human with expertise corroborates it. Glad you didn't act on it.
That was my thinking when I posted the reply front ChatGPT hoping someone with knowledge would support the answer or as happened suggested it was tosh.
