Early last year a damaged (but repaired) Satellite Staro appeared on the used market not far from me for something silly like 50€. I passed it up due to the size, but regret that now as the lighting characteristics would suit a lot of the shooting I do.
I've seen a few cheap Rondos advertised as well but they (and their stands) seem a bit bulkier, so I think I'll hold out for a Satellite Staro.
I think to remember something...
Was this the Staro in question?
A heavy duty repair!
The attachment point of the bracket to the plastic shell is a weak point of the Satellites!
My Satellite has the same defect... need to be repaired. My Staro instead is the improved version with a metal plate.
Here on the left my Satellite with one of the four cracks... 😖
On the right my Satellite Staro has already this metal plate for reinforcement. I think to remember there is also version with two plates on the inside as outside...
If you want a Satellite keep an eye on this weak point! 👁️
You can get also the older Satellites which are full metal but possibly also heavier...
V1
Here an early version of the Satellite (perhaps the first one?), there is no bracket and the full weight is on the lamp.
Positioning must be a bit difficult since very front heavy... 🫤
Note the convenient handle on the back!
V2
Here probably the following version with the bracket...
I think strange the joint point goes through the logo.
Since everything is metal the cracking problem of the plastic version is probably not present.
V3
Later versions lost the handle on the back and don't have the logo anymore on the rim just on the bracket.
The bracket serves now as a handle if you need to carry it.
I had once one of these but not in best condition (the rim rivets falling apart). Paid 50CHF for this AND the plastic one and then sold for 50CHF so the plastic version was virtually free but still need to be repaired... 😐
V4
Then I assume the following version is with the plastic shell.
The joint points are not reinforced.
V5
I was not sure if there was a reinforced version but with a quick research I found this. Clearly this is a reinforced Satellite.
Here the bracket is mounted on reverse... probably by the user for better balance?
and of course for the Satellite you need the smallest reflector made by Broncolor.
I ended having 3-4 of them.
One more thing: the bracket of Satellite has one centre hole, where a junior pin can be mounted.
There are also other four smaller holes. Can you guess for what?
It is for this part here.
What is this may you ask... this is the joint point for the Varistand!
The Rondo-bracket attaches here. You see the scrub marks that indicate the horizontal rotation which I discussed in one of my recent post.
