RichC
sbaruche said:can you confirm that the modern elmar 2.8/50mm can be safey collapse
Sylvain, I've not seen this lens, but I'm pretty sure it can collapse safely. Just make sure that the the collapsed tube doesn't extend past the lens mount more than 20.5 mm.
As I mentioned in my aricle, the worst that can happen is the lens tube will hit a protective ledge in front of the shutter.
