Need help using Summaron
juggler
1:46 PM
Singapore
Hi!
I recently acquired a Summaron 35mm/3.5. I tried it on my Bessa R.
When I want to change the aperture, the focus ring also moves. I had to hold the focus ring still to change the aperture. The aperture ring is quite smooth to turn already on its own. Good thing though, when I move the focus, the aperture does not move.
Is this "normal" behaviour? Should the aperture ring move independently of the focus ring? Earlier on, I was using a Jupiter 8 and Industar 61 and the aperture rings do move affect the focus.
Or is there a technique in setting the aperture and focus? One way is to preset, I suppose.
Any tips appreciated. Thanks!
Hi Koah,
I have a Summaron too. It is not the easiest lens to adjust aperture because the scale rotates with focus. I set the lens to infinity (locked), set the aperture, then focus. It's not as convenient as 2 separate and independent controls, but the results from the lens are very nice. The 50mm f2.8 Elmar (original) works the same way, as do some FSU lenses.
When focussing any lens with a rangefinder, I like to start from infinity (so that there's only one way to turn the focus ring). Therefore I just set infinity lock, then aperture, and finally focus.
Richard
Thank you all for the input. I get the idea. I shall practise those techniques.
The Summaron looks fun. Now I can see more in the viewfinder. 🙂
Will share some results if I can get my hands on a scanner.
Cheers!
