HAnkg said:
Does the Sonnar have a narrower DOF?
no.
HAnkg said:
Is it a problem in the near range, do you need to avoid subjects closer then say 3 meters?
no.
the focus shift is ONLY related to the aperture. measuring as percentage, the effect should be independent from focus distance. measuring in absolute focus difference, the effect is larger at large distance, smaller at close up.
HAnkg said:
If you have the lens optimized for focus at 1.5 will it back focus at 2.8?
yes.
the problem here is, that the design will always be a compromise.
usually, the effect is small enough to "drown" in depth of field for smaller aperture, so you can safely optimize for full open.
as soon as the effect gets stronger, you need to decide where you can accept a deviation from the expected technical behaviour.
for a correctly adjusted lens, the effect should be quite small - just noticeable.
please note, that i can tell only from observing it on one lens, and without knowing the exact specification for lens adjustments given by zeiss.
HAnkg said:
When would you use the Sonnar and when would you reach for the Planar or Summilux?
summicron.
i own the summicron, not the summilux.
to put it compact:
i'll use the sonnar, when i want the sonnar's imaging properties, and the summicron, as soon as i want the summicron's.
as you already said: the sonnar has its special signature.
i regard the summicron as something like a "reference lens".
let's say, for example portrait:
summicron --> neutral or analytic (i don't like the term "clinical" ...)
sonnar --> expressive, "dreamy"
don't nail me on this comparison - the differences are subtle, highly subjective and lie in the eye of the beholder.
asking, which 50mm would i take on the far away island?
answer:
the sonnar.
HAnkg said:
Zeiss must have had some particular application in mind when they produced the lens knowing the designs percularities. (sic)
sure.
it is a classical lens, reborn.
