M4streetshooter
Tourist Thru Life
Well, you guys freaked me out about the 283. It won't be on the camera again but then...what to use....I don't really know which Epson suggest to use.....maybe this is another topic...hmmmm
Just put a Wein safe sync between the hotshoe and flash or between hot shoe and sync cord. Great for use with studio strobes too...........M4streetshooter said:Well, you guys freaked me out about the 283. It won't be on the camera again but then...what to use....I don't really know which Epson suggest to use.....maybe this is another topic...hmmmm
AhShun said:If my "made in Japan" works on a 20D, would it means that it will also work on RD1?
Jim Watts said:I was interested that you use the Vivitar 283 with the R-D1. I have 5 old ones myself, but won't risk using them on the R-D1 without a Wien Safe Sync. I had an e-mail from another RFF member today about measuring flash voltages as I had noted in a post that all my 283's were high voltage, so am curious how you are using yours.
Are you using your 283 with the Wein safe sync or have you measured your 283's voltage and found it OK. http://www.botzilla.com/photo/strobeVolts.html indicates quite a range of voltages for 283's, but most old ones are high. As I recall all mine measured over 200 volts. I was not inclined to risk anything over 25 volts straight on the R-D1.
AhShun said:That's what I'm afraid of...
May be I should look for a voltmeter.
BTW, my 20D keeps working after the 283 fired.
