Contax T vs. T2
raid
Dad Photographer
9:50 PM
Florida
Is there a big difference in the optical qualities of the lenses between these two models? The T supposedly has the better lens.
Raid
steamer: FrankS also has read something to the effect that the lens of the T is the best, followed by the T3 and then lastly the T2. I wonder whether the T2 still has a sharp lens or not.
Raid
The T* 38/2.8 Sonnar lenses are identical between the T and T2. Optically the T benefits from the short base optical rangefinder that can't be fooled like the active IR AF system in the T2 but the T2 does focus a bit closer to 0.7 meters vs. 1 meter with the T. The T* 35/2.8 Sonnar on the T3 is the sharpest of the series benefiting from a much improved passive AF system that focuses down to 0.4 meters. Having used the T3 and T2, the T3 takes slightly sharper images and is more capable but the T2 is much more user friendly and far less fiddley in it's operation.
Chris: I got the Apple. I bought the T2. If I don't like it, I can sell it. I was looking for a small P&S camera with a sharp lens and at a affordable cost. The T2 meets these criteria well. The T is much more costly.
Raid
From what I've seen, any difference in sharpness between the T and the T2/3 is negligible. Because the T is very different from the other two it would make more sense to decide based on operation (e.g. MF vs. AF).
Andrew: I agree with you on this point. I would have preferred the manual focus T but the much higher price would make it too expensive for my current needs.
Raid
Thanks Andrew. I want to make it a companion camera for a medium format wide angle camera in my next trip. If it is not sharper than my manual (guess)focus Minox GT, I will sell the T2 later on.
Raid let us know how your test shots compared to the Minox. Here are mine taken with my T2 @ f/4; full frame, center crop and left corner crop. Compare to the Rollei 35 RF 40/2.8 Sonnar on my Leica MP shown here: http://www.photo.net/photodb/folder?folder_id=696987
Well, for what (little) it's worth, if you're looking for a point & shoot a little more exotic than the Olympus Stylus Epic but less expensive than the Contaxes, consider the Yashica Ts. I had an original T4, with the 35mm f/3.5 Zeiss Tessar. It was quite sharp. Yes, I know; no manual control. Just a thought!
I have two such Yashica's (T2) and both have broken down. I tired them again last night to see if they would function or not. Each sports a Zeiss Tessar 3.5.
Raid
