FYI,
In case you are wondering if the center filter is needed with the M8 , the answer is yes.
I was hoping that the crop factor would have eliminated the need for the filter but it does not. The filter is a -1.5 stop factor. The new Tri-elmat will probably be even more difficult to use because it is already an f4. That plus a center filter makes for a very slow lens unless you are doing tripod work.
The 15 distagon is an incredible lens. The focus is SMOOTHER than any of my Leica lenses and the build quality is equal if not better.
I am looking forward to a lot of hiking this spring with the M8 and 15.
BTW, those who are concerned about the lens not being rf coupled, don't. The focusing range is so narrow that with an f4 or 5.6 setting you literally have a point and shot if you leave the camera on A.
