P&S with 50 mm lens?
fgianni
Trainee Amateur
9:21 AM
Birmingham (UK)
Does such a thing exist? I have a Minolta TC-1 with a 28mm lens, and in the post a Yashica T5 with a 35mm lens, Now if I only could find a pocketable P&S with a 50mm lens I would be really happy, but I seem unable to find one.
Any help out there?
Thanks
Umm Contax G1 with a 45mm/2 Planar? Coat pocket anyway.. Sort of heavy though..
Good question.. Leitz CL with 50/2.5 CV skopar is really small, but far cry from point and shoot.
Contax Tvs - the lens is 28-56 but it's collapsible... and aperture priority...
http://www.tarosworld.com/photography/Gears/Cameras/Contax_TVS/index.htm
http://www.kiwi-us.com/~mizusawa/penguin/CAMEdata/kyocera/image/TVS_1.jpg
If I had the money I'd get this one... but for me it's pretty expensive for a P&S 🙁
The problem is that usually zoom compact have miserable maximum aperture at longer focal lenghts, do you know what is the maximum aperture at 50mm?
Thanks
the lens is 28-56 f/3.5-6.5 so yes, it is pretty slow... but considering it's a zoom and that you only need one camera and you have 28-35-40-50-56 it's not bad... most average P&S are like 38-80 f/4.5-9... 🙁
Can the elmar safely clear the CL meter arm? To me the IIf shape can fit a pocket better than the CL, but maybe it's heavier. Sadly I have no T3 to compare.
Is 40mm good enough for you? Or do you really require the extra 10mm in focal length?
Just have a look at my avatar. The Industar 22 (elmar copy) collapses safely (95% collapsed) on both CL's I owned, stopped by a metal frame inside from hitting the shutter.
Clarence
