Biggles said:
Refresh my memory, please: Were both the Zeiss f/1.5 and f/2 50mm Sonnars made in Leica screwmount, back in the day? And were any ever made in M-mount?
What should one expect to pay for a Leica-compatible coated f/2 Sonnar?
No M mounts. A variety of LTM mounts, there is a 50/1.5, a rigid 50/2 and a collapsible 50/2.
If you want a coated one, end of war-time lenses are easiest to find, but they normally have an aluminum barrel and look very similar to early
Jupiter 8 and Jupiter 3 lenses. The coating is soft, so it's difficult to find a clean lens. There are a lot of fake ones out there. Make sure that the
front barrel has a Zeiss serial number (seen when un-screwed from the focus mount), and that
the focus scale has a small "m".
Also, many of the LTM mounts out there might have been home-adapted (during war-time, see MJ Small's book on non-Leica LTM lenses), and
not by Zeiss.
Kevin has both a 50/1.5 and 50/2 listed on *bay for US 450 or so. He also has several others on his web-site. Expect to pay between US 300 to 500.
An early Russian lens (ZK) or a newer one adjusted by Brian or Kim
are very good alternatives.
Another alternative with very similar signature, but better built is the Canon 50/1.5. Also, from what I've seen from the new
ZM Sonnar, the signature is very similar with more modern coating.
Best,
Roland.
