Nokton 40 1.4 lens focussing sticky and noisy
justins7
12:59 AM
My 1-year-old Nokton 40 1.4 has a crappy focussing mount. I know people complained a bit about this when the lens first came out. It's a weird mount; you cannot focus and turn the aperture ring at the same time.
But now mine makes a horrible squeek when I focus, and you can feel the rough, metal friction. Is there some way to lube this thing myself?
Thanks.
Thanks.
The outer focus helical is directly accessible when taking the mounting
flange off. Try if this fixes your problem.
Roland.
justins7 said:
My 1-year-old Nokton 40 1.4 has a crappy focussing mount . . . you cannot focus and turn the aperture ring at the same time.
I can certainly do that on mine (a few months old). Sorry to hear about your problem. Mine works well and I assume your can be adjusted or repaired if need be.
yes PLUMBERS GREASE will work well for brass . plumber's use it to lube the brass vavles in faucets and bathroom fixture's . should come in a small can like shoe polish . just use a small amount on a brush and focus the camera back and forth to work the grase into the threads .
