Luigi Half Case
PaulGuy
2:19 AM
I've been admiring photos many of you have posted of your M cameras clad in these beautiful Luigi half cases. Then I began to wonder, it looks like you'd have to remove the strap everytime you want to remove or put film in the camera. Is this true? Do any of you find this...well annoying?
Luigi Half Case
Not sure you mean neck strap removal? Anyway, I use Luigi cases a lot, and the case must be removed for film loading/unloading. This is easy with two snaps and the little keeper flaps flip right out of the way. The main problem is where to put the case while it's off. I don't use Luigi neck straps, just the half cases. The cases have a very nice feel to them and make gripping easier with a small pad built in the front.
luigi, not just for leica!
joe
Okay I get it now. On Luigi's website I see the case snaps in the back. I thought there were just two holes cut out for the camera lugs to come through.
Duh!
Another vote for Luigi - fantastic cases which have really enhanced my enjoyment of shooting with my M's. The little built in 'bump' at the front helps grip the camera and I find I no longer worry about where I set my Leica down to avoid scratching the baseplate etc.
When changing films outside I find the case, once removed, is a good place to rest the baseplate to keep it clean.
dan
