M8 and cyan shift?
usccharles
10:42 AM
hi,
can someone give me a image example of what cyan shift is? i have been using a 15mm VC Heliar without any filter for about a week, and i haven't noticed any 'cyan shift'
then again, i don't know what a cyan shift looks like 😛
cyan shift
cyan shift
If you use your lens with a ir filter you will see it Without the filter you wioll not. Though wothout your colors can be off with syntheticaa green grass and other times David
Make a circular gradiant in ps complimentary to the shift. Try red to start. Move the sliders around so it starts where the cyan comes in.
Now apply in the center of the frame and it will cancel the cyan depending on how well you make the gradiant.
