flash for wide angle
thefsb
7:53 PM
seems there's a lot of wide angle fans among the cv users.
so what do you do, or suggest, for achieveing wide angle flash?
just for one example, if you were at a party and using a 25mm (or wider?) lens to get lots of people into each shot.
any particular equipment? or techniques?
Avoid direct flash. Try to bounce it off the ceiling or walls and the spread will be much larger too.
If there's nothing to bounce with (like dark walls or outside) then try shooting your flash vertically into an empty milkjug held up high.
I'll second or third all that. Bounce is best, diffusion if all else fails.
I've shot some frames with the 15mm and a standard automatic flash and found the 'vignetting' pleasing under some conditions, though.
