mr roberts
Just R
HKSupplies
HKSupplies
Very reliable and reputable. Make sure that the junk/spam blocking of your email or ISP isn't blocking their messages.
I heard back from them about 3-4 days after I placed my order and received it in about 8 days by Post.
I don't think that you have anything to worry about, but if you're concerned I would PM them again with your transaction number info from their *bay store.
Good luck.
HKSupplies
Good luck.
Ted Witcher
I got mine from HK via eBay. It works fine, except the tolerances on the threads aren't very tight, which requires some fiddling to get it on properly. Other than poor Chinese QC, it performs as advertised.
sleepyhead
raid said:Such an magnifier would be great on a CL or CLE to allow more precise focusing with long and fast lenses. I love my CLwith its 40mm lens, and I would like to use a90mm on it wide open.
Raid
Hi Raid,
yes, I find the 90mm framelines on the CLE a bit small - I have the 1.35x magnifier from megaperls for my M4-P and like it alot - I held it up to the viewfinder of the CLE and I think it's a quite good view - I can still see the whole 40mm frame, and the 90mm lines look better.
I'm currently working on a way to fix the 1.35x mag on the CLE without modifying the CLE too much.
Will keep you posted...
John Elder
Received My HC 1.25 Magnifier today and it works very well . I can't imagine paying the ~270.00 for the Leica Brand. Good deal!
clarence
ダメ
Would cellophane tape or sticky plasticine adhesive work as a temporary solution?
Clarence
Clarence
sleepyhead said:Hi Raid,
hth
Any words on someone producing a magnifier like this for the Hexar RF?
/Håkan
/Håkan
Robin Smith
I use the 1.25 on a 0.72 M, but very rarely. I can't say I would be devastated if I lost it. It is helpful when shooting at wide apertures with the 50mm and higher lenses, but it is not exactly a pleasure to use as I am a glasses wearer. Also of course they are not so good in dark conditions as the vf image brightness is reduced (or more accurately, the brightness is the same but apparently reduced as the existing image is simply magnified). I got mine cheap so I am not disappointed with it. Personally I advise you to try it out before you buy to see if it is worth it for you.
In short: a good idea in principle, but less inspiring in actual use.
K
Kyle
Guest
Robin Smith said:I use the 1.25 on a 0.72 M, but very rarely. I can't say I would be devastated if I lost it. It is helpful when shooting at wide apertures with the 50mm and higher lenses, but it is not exactly a pleasure to use as I am a glasses wearer. Also of course they are not so good in dark conditions as the vf image brightness is reduced (or more accurately, the brightness is the same but apparently reduced as the existing image is simply magnified). I got mine cheap so I am not disappointed with it. Personally I advise you to try it out before you buy to see if it is worth it for you.
After receiving mine on Saturday, thats about how I'd describe it.
Completely unusable for 35mm frames (not too surprising) and more difficult than I expected for 50mm frames... and I don't wear glasses!
