1.5/50 ZM flare (or what is this?)
firebird
1:13 AM
Stockholm, Sweden
Why do I get this reflections/artifacts from my 1.5/50 ZM.
Any hints or ideas ?
It's mounted on a M7 and I do not see this phenonema with any other lens.
/G
It seems to be in the same position and similar in shape in every photograph, so imho it should not be a flare.
Probably a pinhole in a shutter curtain?
Strange... those artifacts show up in the same place, and seem to have similar pattern,no matter what's the camera/lens position against the sun. Do all photos come from the same roll? Looks like burned shutter to me.
other than looking like a ufo that follows you around, it is not lens flare and looks like shutter curtain pin holes and cracks.
This cannot be flare - in two of these shots you have the sun over your shoulder. Most likely it is a hole in the curtain, or it could have been a hole in the film cassette. See if you get it with other films.
I tend to lean toward the "leak in the curtain" theory eventhough I thought I should have seen similar issues with other lenses as well.
It only shows with this combination of lens and body (regardless of film)
