Blooze
Something I am doing is definitely wrong. I've had this happen on the last 4 rolls of film. Mix of Tmax 100 and 400, three different cameras, and two different developing tanks (Paterson and Kindermann stainless).
I had streaks similar to this before, but a little wider and more pronounced. I ended up after drying refixing them and rewashing and everything turned out fine. I have not done that with these.
Film is developed in ID-11 1+1 and 1+3, Ilford stop, and Ilford Fixer. 30 second continuous inversions then 2 gentle inversions every 30 seconds. Even with fresh fixer at an 8 minute fix I was still getting these, if it's the fixer. Weird thing is it happened with two different tanks. I thought the Paterson was the culprit, but the example below is from the stainless tank. Then maybe not enough developer. The stainless only holds 470 mL and I'm putting 450, leaving a little 1/8" of headspace. It's a good 1/4" above the reel. It's obviously something I'm doing wrong, but I'm not sure what.
Any suggestions as I'm getting tired of cropping off the edge or cloning it out. It's on the right edge and on my calibrated monitor it sticks out like a sore thumb.
