1942 Coated Summitar Info help
It may be that the coating started a bit earlier, or that some lenses were recoated during the war years. I have Summitar 526607, which conventional wisdom places as 1939 production, and it has a strange light blue coating rather than the darker purple coating I have seen on later lenses. The lens has the older F-stop sequence, and a distance scale calibrated in feet. Would this have been coated after the war, but with a different material than usual?
Dez
It's many years later, but did you ever figure out the origins of this lens?
I have a very similar lens except with meter "mtr" markings with serial 528863 if I remember correctly. The f stop sequence is 2, 2.2, 3.2, etc.
The coatings appear to be very light blue.
Surprisingly there is no haze but faint "cleaning marks" it seems. I'm afraid to clean the front element.
