1963 Morgan + 4
farlymac
PF McFarland
6:22 AM
Classic hand-made British automobile.
Ready To Roll by br1078phot, on Flickr
Eight photos at
https://www.flickr.com/photos/7699588@N07/sets/72157647048054608/
PF
Yep - there is a good bit of hand work needed to cobble the body onto the frame.
I can't remember if the subframe for the body tub was made of teak or ash.
There is a common misconception with Morgans that the chassis is made from ash, it isn't, the chassis is made out of steel. Ash is used for the structure of the doors and body work. The outer panels are attached directly to the ash framework.
Glad to hear that. I'd not fancy splinters in me arse from an accident.
A long time ago I met a woman who said she wanted a Morgan. "The horse?" I asked. "No stupid, the car" she said. It was one of those things that you smile about years later, but you feel somewhat bruised about at the time.
As I recall, Morgan patented an early "sliding pillar" independent front suspension around 1911, and they continued to use this rather primitive setup at least through the 1960s.
Also, as far as I know, all the other British sports car manufacturers quit using wood in the bodywork by the mid-1950s. (I'm thinking most specifically of MG, who I believe used wood through 1955, in their TF model. With the advent of the MGA in 1956, wood was no longer used in the car's structure.)
Thanks for the photo of this old Morgan. This is from the time when I started getting interested in (European) cars, as a boy. My dad drove MGs for 17 years, from 1951 starting with a TD, through a TF 1500, an MGA, and an MGB. I still drive a car with a stick shift. 😎
- Murray
