20mm russina lens on bessa L
S
saiseto
Guest
I'm planning to buy a Bessa L and just wondering if anyone know if the russian 20mm russian lens would be able to use on the L body. As the back of the lens is too long that actually can't fit on my bessa R2A. Also, I would be grateful if anyone can share the experience the use of the bessa L with me. Cheers!!
If it doesn't fit the R2A I doubt it'll fit the L.
The L is a really nice camera. Get the case as well as it adds a bit of bulk and grip to the camera's body.
In combination with the CV 25/4 and external VF it's a wonderful street shooter. Nowadays I mainly use my Bessa R and Leitz Minolta CL, though, as they are a bit more convenient for my shooting. However, if either would break down I'll bring the L in a second.
For some shots taken with the CV 25/4, check my galleries.
Anyway, for $69 from CameraQuest the L is a true bargain.
You'll love it.
Hi, and welcome! I've had a Bessa-L for a few years, used mainly with a 15mm lens and sometimes with a 25mm (which was part of the package with the L).
The Bessa-L is an odd camera, and that's part of its charm. "A camera with no viewfinder??? Why would you want that?" I look on the positive side and see that it's not a box camera with fixed focus and little or no exposure control; indeed it even has interchangeable lenses and TTL metering! But it certainly is a move toward simplicity.
This is a good camera to develop your skill in judging distances, and to get a mental grasp of the concepts of depth of field and hyperfocal distance. Dedicating this L to one wide-angle lens, while also carrying another camera with longer lens, it worked very well for tourist pictures in cramped areas, indoors or out.
In decades past many good cameras had no rangefinders, and so the user estimated distance by eye (or by string with knots!). Even medium format cameras with their 100mm or so lenses, that have much less depth of field than a normal lens for 35mm format. Slower lenses are less critical of course. I took only a 6x4.5cm format camera on vacation once, that had problems with its rangefinder. But estimating subject distance or using the hypefocal distance worked fine, just as with the Bessa L.
This can actually be a very fast way to work, if you also apply the same kinds of techniques to exposure as for focus. "Sunny 16" and all that... It reduces the need to fiddle with the settings for each shot, as you pre-set your camera for the environment you're in. Thus your reactions can be very quick indeed, in just bringing the camera up and squeezing off a shot. Maybe not even using the (accessory) viewfinder!
This is a very different way of working from the slow, thoughtful, and precise operation of a view camera, at the other extreme. More of a quick-reaction ad-hoc intuitive operation... maybe that's why Voigtlander calls their 25mm lens the "Snapshot Skopar"! Of course as the light grows dim, you will want to set the L with more care as well.
I don't remember the depth specs on the 20mm Russar (they tend to be pricey but they are very good lenses) but it seems to me the Russar doesn't go as deep into the camera as the Jupiter 12 35mm lens. The Bessas seem to have problems because of the internal metering. I don't know if the Russar will clear it but I would think there might be less expensive WA alternatives
You'd be better off with one of the Cosina/Voigtlander lenses. That way you know they will fit the Bessa L. And I agree with RML: If it won't fit on an R2A it also will not fit on a Bessa L.
I have a Bessa L with the 25/4 "Snapshot" Skopar. I just got it a week ago and I must say it does take a bit of getting used to, but the learning curve is short. By the end of the second roll I basically had it figured out, and Doug's comments are quite insightful and spot-on. If you go to my gallery and check out the cactus picture...I balanced the camera on my foot and didn't use the viewfinder at all. It was my first attempt at seeing how close I could get to an object.
Instead of the 20mm russian lens, why not the CV 21? What's a millimeter here or there?
Ted
