21 f/4 Super Angulon M mount
bucs
6:51 PM
Manila, PH
I have read that the 21 4.0 SA in M mount can be used in LTM bodies by removing the bayonet mount which is screwed onto the body.
Can anyone confirm this? TIA!
Nathan
Nathan,
I have one of these lenses. There is a tiny set screw that you will have to unscrew. Be prepared to catch it 🙂 After removing the bayonet mount, you have a regular LTM mount.
I don't believe that all 21mm f/4 M mount lenses will allow you to do this. I'll leave this question to the Leica experts!
This lens works well for me on film.
Mark
Is it this screw on the side of the mount?
https://www.dropbox.com/s/t8v7zzxwsg2hhah/P1010564.JPG?dl=0
Nathan
Nathan,
Mark
According to the Leica Camera Forum wiki, all the f/4s have this mount. But, there are always exceptions!
http://www.l-camera-forum.com/leica-wiki.en/index.php/Super-Angulon_f%3D_2.1_cm_1:4
Well … This ^ list is more confusing than helpful, there are too many lenses admixed that aren't the original SUPER-ANGULON 1:4/21mm aka «SUOON».
(Let alone the designation «Super-Angulon f= 2.1 cm 1:4» is an invention of that forum over there [obviously, one can call that Bravo Sierra, I'd say].)
And: Has anyone ever seen a «SUOON-M» made after say 1963 having the aforementioned removable M-adapter? — I guess it's an urban legend.
According to Dr. Bawendi, only about 1.400 SUOON were made.
And: Has anyone ever seen a SUOON-M made after say 1963 having the aforementioned removable M-adapter? — I guess it's an urban legend.
That list is a bit long, as the f/4 model was not made until 1980. The 3.4 model takes over from 1964 (or 63 or 67?) through to 1980 (or 81). So one must presume that the f/4 list contains R lenses, or f/3.4's in M (or R) mount. Some cross referencing is required to really drill down into the list. But, the page clearly states;
Lens mount - Leica Screw-thread and unique M-bayonet addaptor removable for screw-mount use
Whereas the f/3.4 page lists the mount type as;
Lens mount - Leica Screw-thread & M-bayonet
Which clearly doesn't state that the convertible mount exists in the f/3.4 version. (I've never seen a f/3.4 is thread mount though...)
In the end, it turns out that there are exceptions to every rule, and you only know when you see it.
  • Lens mount - Leica Screw-thread and unique M-bayonet addaptor removable for screw-mount use
Thank you, Michael!
Well, not only the «2.1 cm» nonsense, and this until the 1980s, additionally they're talking about an «addaptor», whatever that might be 😉
Thank you, Michael!
I think we may have a lost-in-translation situation from German, I assume through several languages, before finally into English of some sort. 🙂
And being European, it surely should be 2,1cm rather than 2.1cm! Such a travesty!
😀 Funnily, the one and only (!?) author of the list in question appears to be Texan (if the email address is an indicator), at least their name is English.
—— Perhaps this author is so proud of their understanding of the metric system (Hey, is 21 millimetres actually 2.1 [2,1] centimetres? Isn't that weird?), that they must show it everywhere 😉 ——
Now that I look at the revisions (a self moderating wiki is bound to be accurate with one user 😱) I can start to dig...
I appears that sometime on the 6th of March 2010, the production timeline changed from;
''Production era''' - 1958-1963, 1462 screw and 5292 M-bayonet lenses
to;
'''Production era''' - 1958-1981, 1462 screw and 5292 M-bayonet < 27,000 lenses
and we added an additional 20000 lenses that we cannot account for? (Total R mount SA, both f/4 and f/3.4 is less than 10000, so still 10000 unaccounted for) Seems fishy?
Now, I notice something else. The wiki lists 1462 screw mount and 5292 M mount, but it also lists that all the f/4's were a convertible mount...
Some more digging and the total production of the f/3.4 version is listed as < 5970 lenses.
So... now can we finally see that in the total 21mm (or 2.1cm) Super Angolan production (excluding R mount) was:
~ 1462 convertible screw mount f/4s
~ 5292 (< 5970) M mount f/3.4s
Now, what was the question? 😀
Nathan
That screw is stopping the M mount unscrewing off the screw mount. I would be careful, its likely been sleeping there for 60 or so years 🙂. Once remover, the M mount "should" just unscrew as if you were unscrewing an LTM-M adapter. Take care, the thickness will not be much and it will probably be stiff.
Pic
Pic
Here ya go
