WJJ3
Hi folks,
I am interested in what people's thoughts are on eye relief of 21mm finders.
I am using the Voigtlander 21mm plastic finder, have tried the current Zeiss 21mm finder as well, and find eye relief to be not so good on either. In full disclosure, I have to admit I feel eye relief for the 35mm frame in a standard 0.72 finder is not good; to the point that I bought a 0.58 M6 to shoot the 35mm focal length. So I know I am already pretty picky regarding this, but I would like to hear others' thoughts about eye relief, and 21mm finder eye relief in particular.
Thanks and happy shooting!
02Pilot
Malcontent
I just got a CV 21/4 with the plastic finder. Without glasses, I don't have any problem with the eye relief; with them, I can see where it might be something of an issue, but there's still a good bit of space around the brightlines.
That said, I shoot with a lot of old cameras with squinty finders of dubious worth, so any big, bright VF with framelines is going to be a marked improvement over what I'm accustomed to.
WJJ3
Thanks for your reply. I actually found the eye relief of the Voigtlander finder better than the Zeiss finder, so it's probably pretty good.
I wonder how other 21mm finders are...
Dez
Bodger Extraordinaire
I recently bought a Ricoh GV-1 finder, which has brightlines for 21 and 28mm lenses; just right for me as these are my wides. The view is excellent, clear, and undistorted, with plenty of eye relief with or without glasses. I take a -2 diopter prescription, and the image is sharp for me without glasses.
BUT, there is a bit of a challenge. The shoe on the finder is offset to one side, so if used on a Barnack or most M's, the body of the finder covers the shutter speed dial. I had assumed that the shoe could be moved easily over to the other side as was the case with a lot of old shoe-mount accessories. I assumed wrong.
This finder will spend most of its time on my M5 where the shoe position is not a problem, but to fit it to other cameras I was forced to bodge up a little adapter, by taking a flash shoe adapter block, slicing it across the middle, and gluing the halves back together with a large offset. Easy to do and kind of fun, so I can now use the finder on other cameras as well.
Dez
Dez
Nokton48
I recently bought a 21mm Yashica SLR finder, I had read alot of good things about it on various Leica forums. It tends to normally go for a lot according to the Cameraquest website, so I was extremely lucky to get it. It was either that one, or the Leitz finder. I'm glad I got the Yashica.
I'm enjoying using it on my mirror-lockup Minolta SLR's with 21mm lens. It has excellent eye relief.
burancap
I am an eyeglass wearer, but not for photography. I prefer diopter correction, -2.0 in my case. I have the black rectangular Leica 21 matched to the later 2.8 lenses. I find there to be little to no relief and in my opinion, the framelines are hard to see. That said, I find it surprisingly accurate.
jcb4718
I have the Leica black plastic 21mm viewfinder. I can use it while wearing my glasses and find it provides a good side-to-side view. The edge of the viewfinder coincide with the framelines so you can't see anything outside the them. I really like it.
WJJ3
Dez
Very cool solution! And the 21/28 frameline combo seems much more practical than the 21/25 from CV.
The eye relief of my CV 21mm is not bad, so I can imagine this is working fine for you. Thanks for sharing
WJJ3
Interesting about the Yashica finder. Does it have brightline frame lines?
WJJ3
I am particularly interested in this finder. Is this the metal 12002?
Unfortunate to hear the frame lines are hard to see. The form factor looks great, and I was hoping the view would be too. I wonder if the diopter decreases the eye relief at all?
WJJ3
This seems like one of the best options. Glad to hear you are having success with it. It sounds like there were several iterations of the plastic 21mm finder...
Nokton48
Nope, the Yashica does not have brightline frame lines.
https://www.cameraquest.com/yas2133.htm
ChrisN
Striving
I have both the Voigtlander 21mm finder and the Leica 12 2008 (black plastic) finder. The Leica finder offers more eye relief (about 2mm better) but is a little more distorted than the VC finder. The VC finder is a slightly higher magnification and gives a very bright image with less distortion than the Leica 12 2008.
burancap
I am particularly interested in this finder. Is this the metal 12002? Unfortunate to hear the frame lines are hard to see. The form factor looks great, and I was hoping the view would be too. I wonder if the diopter decreases the eye relief at all?
Sorry, mine is the plastic variant and there is NO diopter correction involved with the finder itself. At 21mm, I do not need to have a clear image -perhaps that is why I have a tough time with the framelines? Anyway, like I said, I found it be accurate regardless -at least as accurate as one could hope for at this width.
FrozenInTime
There is always the Frankenfinder #12011.
I can still see the full 21mm frame an inch back from the eye piece.
It also takes diopters .
WJJ3
This sounds great. It's too bad its such a huge thing. I guess thats what it has to be to do what it does. I'd bet the 12011 on an Md would be a great super-wide rig...
WJJ3
A couple mm's might be a game changer for me. This might be the route I go...Thanks for your input!
WJJ3
This is the finder I am using now. It has enough eye relief for me. I can definitely say this Leica finder has better eye relief than Voigtlander's plastic 21mm finder, and Zeiss' 21mm finder.
barnack by WilliamJosephJefferson, on Flickr
