24mm summilux question
hrryxgg
9:22 AM
i have an m6 (.58) and was wondering could the 24mm summilux be used on that camera without using an external view finder?
and same on an m10?
thanks!
If you can live with loose framing yes.
If not an external VF may be used for more accuracy ( not really so accurate ) in framing and less finder blockage.
For example in M10 's VF, lower right 1/4 is to be guessed.
The frame's couple seen is 35/135mm .
Good news, with M10 you can use LV.
