gfdal
Dear all
Last week end, while cruising around with my MP + 35mm f2, the camera decided to drop from my shoulder and hit the floor
. Hopefully, it happened when I was bending to get something from the floor, therefore the fall was not that high. There are no mark at all on the camera nor the lens. But now, there is a hard point on the focus ring.
I wonder if it is an important damage. Will it - according to your experience - affect image quality (focus). And is it repairable?
Thanks for your help
Alain
Alain
waileong
Drop
Drop
This means that the lens mount could be out of round.
It should be repaired. Otherwise the extra grinding will cause problems for the lens.
Send it to a pro Leica repairer if you value the lens.
Wai Leong
Drop
Wai Leong
gfdal said:Dear all
Last week end, while cruising around with my MP + 35mm f2, the camera decided to drop from my shoulder and hit the floor. Hopefully, it happened when I was bending to get something from the floor, therefore the fall was not that high. There are no mark at all on the camera nor the lens. But now, there is a hard point on the focus ring.
Alain
Alain,
Sorry to hear about the accident with the camera! I assume the lens has a rough spot on the focus both on and off the camera. Is it covered by Leica's "passport" warranty?
From one of out sponsors:
"The Leica Passport Protection Plan will completely protect and cover
the equipment against manufacturing defects, parts and labor, and
will even cover damage to this product, including breakage, water damage
or any accident, excluding fire or theft. "
I would have the lens, and camera, checked over.
gfdal
Thanks all for your reply. Yes, it is still under warranty. So I will have the lens checked out by a pro. Better do it early before it gets worse!
Alain
Alain
Fred
Feline Great
If possible try another lens on the MP, this should give you an indication of likely damage to the MP. If the lens and body are under Passport then it's possinbly worth getting the whole lot checked anyway.
jaapv
RFF Sponsoring Member.
If the lensmount is out of alignment on the body it can only be checked using a special tool.Just putting another lens on it will not tell you whether it should be aligned. It would be wisest to send body and lens to Leica.
Sorry to hear about the accident, but don't worry about it. This time it didn't even have a scratch. But even if it had:Mechanical damage can be repaired perfectly :angel: and any dents or scratches, well, you bought your Leica to make great pictures,not to show it off, didn't you? Dents, scratches, scuffing,these are honorable battle-scars.
