35mm lenses
Dath
8:12 PM
It seems that there are 3 different lenses for the bessa R2 in the 35mm flavour.
The f1.2 is really expensive.
What about the classic f2.5 vs. the ultron f1.7. Is the ultron really any better overall, apart from the fact it can work in lower light more easily?
Does it have better quality over the f stops compared to the classic?
Any help here would be great thanks.
Well, you can always consider the Jupiter-12. Find a good one and it's the equal of any of the rest. I'm not a big wide angle person, but I do dearly love mine.
At 2,8 it is a bit slow, but by the same token it is decended from one of the greatest 35mm designs of all time. 6 of one: half a dozen of the other.
William
I have an Ultron and the Pancake II and I use them regularly. In my opinion the Ultron is sharper and more contrasty then the Pancake II, but only slightly. I shoot in available light and the extra stop does help. Do take a look at my photos in the gallery if you want to make comparisons. 🙂
Thanks David! Ultron is really a great lens you should get one as Cameraquest is selling it at $399.
Dath said:
Sorry, just need to clarify, is the Ultron a little slow at 2.5 or is the classic??
Thanks.
The Ultron has a maximum aperture of f/1.7, roughly one full stop faster than the f/2.5 Classic. Likewise, the 35/1.2 Nokton is about one full stop faster than the Ultron.
Choice is good, isn't it?
I've currently got the Ultron, and did have the Classic. I only replaced the classic with the Ultron cause I found I needed that extra stop sometimes (it can be pretty dim in rainforests)
Both lenses are very good, exceptional when you consider the price. Is the Ultron better? As Peter said, maybe a bit sharper and more contrasty. But......it's twice the size and weight. Really, if you don't need the extra stop I'd be tempted to go for the minimal size.
tim
Consider it as part of your kit. Will you have another fast lens? The Ultron may be the best 35 choice because of it's speed if your other lenses will be slower.
Ultron is a great lens - I love mine so you can't have it 😀
Whether the extra stop is worht it is something you need to answer. I love shooting in dark bars, and at night so for me it is worth it. If I could afford the 1.2 I would get it in a flash, however it is a bit out of my price range.
When using an SLR I could never get the hang of the 35mm, however now I use it regularly on my M3 (using the outside of the frame as the border) I love the focal length.
Well, I have the 50mm 2.5....so I was thinking of getting the 35 1.7 just to have one lowlight monster. 🙂
I would highly recommend it. I have a problem of using FP4...I need to move into the FP5 once in a while too.... 😉
Yea, I don't want to take a flash overseas with me...
I've heard a few horror stories about defective 1.7's, can anyone confirm if the pitting etc is still a problem?
Is it possible (as I live in Australia) for me to request that B&H or whoever I get it through physically check it before they send it to me???
I leave in Mid-Feb and need to master this new machine...
Popular Photography tested both lenses, using the same methodology. They found the Ultron to be the better of the 2 lenses. You can check the July, 2000 issue for the details.
I tried mounting my J-12 on my new Bessa R (very carefully, of course), and checked what happened with the shutter curtains open on B: it does mount close-focussed, but one cannot focus to infinity, because the rear element hits a ledge inside the camera when doing so; also, the metering cell is covered, so no light-meter function...
Good that I did not take a risk when ordering my Bessa R - it was the right decísion to get a 35mm Color-Skopar as well!
Roman
PS: My J-12 is a black one, without the metal collar around the rear element (that some early chrome ones have).
Dath - if you ask Stephen Gandy of cameraquest.com, i'm sure he will check out the lens thouroughly before sending it. He is a great guy to do business with - where are you in Australia? mainline photo (australia) stocks voigtlander gear at quite reasonable prices.
hmmmm...didn't realise you were in Aus. If you're anywhere near Sydney, if you want we could meet up and I'll lend you my R2/21/35/90 combo for a day so you can get the feel of it.
tim
ah, yeh, that's not quite easy.......
still, if you were down in sydney the offer holds 🙂
and i'd second mourges comments re mainline. scott is good to deal with and quite reasonably priced. getting stuff sent from the us usually attracts import duty, so unless it's a _lot_ cheaper or is something you just can't get here, i find it's quite often not worth it.
cheers...
tim
Ooh, ooh!! Another Melbourne member!
Mourges, whereabouts in Melbourne?
I'm in Hawthorn, and I think Kris is St. Kilda - I feel a January get together coming on!
Steve
