RayPA
Ignore It (It'll go away)
Dougg said:...
Example below of what I like to do with a 35mm lens...
Nice shot, Doug!
Dougg said:...
ghost said:you can see it in 'self portraits'.
koudelka accidentally received a canon 25mm instead of a 35mm. in another world...
I'd like to know more about the reasoning in your choice of 35mm or 50mm lenses as your main lens. Paul[/QUOTE said:Paul: I think that reasoning has little to do with it; I think we learn to see iamges with a certain implicit angle of view, as well as other visual characteristics. This might be because of our favorite family photographs from childhood or a photographer to whose work we've responded. Interestingly enough, my favorite
lens is a 50, whether I am using an M6 or an R-D1. I find it more of a challange to get the look I'm after, both in terms of depth of field and angle of view, with wider lenses. This doesn't mean that I don't use them, I just use them less often than I do my 50s.
For the holiday's, I have extended family visiting and will be taking a lot of group pictures indoors. I made sure to get a 24, which I had loaned to a friend, back for the occaision. Now that is rational problem-solving. But when I head to my in-laws. . . the 50 will be on the camera initially.
Bob Helmond said:In case you've not read my previous post on another thread, the 35mm Summilux has served me well for nearly 30 years of street and available light photography though it is not the lens for every occassion.
The shorter focal length permits hand-holding at slower shutter speeds than the 50mm.
It's wider field of view allows the photographer to get more up close and personal with the subject.
It magnifies objects closer to the camera more, thereby creating a greater spacial separation between foreground and background of the image.
The lens is physically smaller and makes the camera easier to carry (and conceal when necessary.)
Increased depth of focus forgives slight errors in focusing in fast-moving situations (except at maximum aperture.)
The width of the field of view of the 35mm lens is roughly equal to the distance from camera to subject. So if a subject is 12 feet away the film will record a field of view of approximately 12 feet by 9 feet. This information comes in handy when shooting from the hip.
So there's six reasons for using a 35mm. Can anyone come up with as many for using a 50?
Well put.
An M3 was my first camera, and like many a 50 was my first lens, a nice match. But something a bit wider was the way I was 'seeing' so the .72 finder M-series cameras and a 35mm became my most used combination over the years.
Part of the attraction of the 35 was its compact size ( pre-ASPH days ), easy to carry and use, its a very forgiving lens as long as you fill the frame.
A 35mm lets you get in close with people, and also back away to get the whole environment, buildings and landscape without the wide-angle look. Along with a 50mm its my usual 2 lens outfit, with the 50 for concentrating on details and my 'long' lens.
