35mm Summaron w/Goggles works with all.
phototone
4:26 PM
Van Buren, Arkansas USA
I just wonder if you all knew that the 35mm Summaron wide angle with goggles will work with all the "M" Leica's, even though it was made for the M3.
On the M3, it brings up the 50mm frame, and the goggles show a wider view within those frames.
On the M2, it brings up the 50mm frame (which of course is smaller), and it shows a wider view within those frames. The field of view is identical.
Should be the same on the other "M" cameras. It will bring up the 50mm bright frame and the goggles will show a wider view to correct for the 35mm focal length.
