35mm Summicron ASPH: The ugly lens?
Let them believe what they want. Whatever makes them feel good.
X-Ray,
I think I might quote you on the bottom of all my future posts !
Pretty much sums up how I feel too ! (on more than just the subject of lens rendition).
BTW see that you live in Tennessee? I'm just to the south in N. AL.
Maybe it's a "livin' in the south thang" but suspect it's more of a old guy thing 🙂
For those that think I'm full of S#%T then take a moment and think about this. If you're not in total control of your process, printing and film development, and and you can't repeat exactly the same result day after day then the results you are getting are purely accidental. If you can't repeat the same result every time then how do you know of the lens is flat or the process is flat or the lens is contrasty or the film is contrasty. The lack of consistency influences the final result. Can you make one print per day exactly like the print you made a year ago? Put your camera on a tripod and shoot 36 exposures of the same subject at exactly the same exposure. Clip six inches of film each day and run it over a period of a month until all is processed. Compare your results side by side and then with a densitometer. Most likely you'll be al over the place in contrast. Are your results accidental whether good or bad and can you repeat them? You have to eliminate the variables before coming to a conclusion otherwise you're conclusions aren't valid.
X-Ray,
I hope being an old guy isn't a total waste of time and something good comes out of it.
Very well said. I had a remarkable photo chemistry teacher, Paul Krot who made this very clear, and I took it to heart. Like in so many things, it is practice and attention. When I started my project shooting B&W in the woods I spent the first half of the first summer simply testing films that seemed promising. Running them in various developers to find out first if what I was after was possible, and two if it was repeatable. I find nothing worthwhile in investing the time and energy into shooting if the results are going to be a crapshoot.
One thing I can add is to write down a record of what you do. I do this for all my printing/developing; it is a great way to force yourself to get repeatable and predictable results. Tweaking is fine, but only once you know what the variables do in the process.
You brought up a good point here. I agree many of the RFF's are shooting c41 B&W film and taking it to Costco, Walmart or some other amateur lab with little to no QC and people who couldn't care less and have no knowledge or drive to keep a process in control. Scanning is another issue too vs silver gelatin printing. To my knowledge none of the current traditional process B&W films were designed for direct scanning but rather to wet print in a darkroom. How many people or labs scanning negs do anything other than use the canned generic profiles if any profile at all? How many people really know anything about scanning negs other than feeding them in and saving the image. Every film has a different profile / scanner curve / profile set and every scanner is different. Scanning is different on a drum vs a low end flatbed (under $8,000) vs a high end dedicated scanner like the Imacon (over $10,000). You're not going to get the same results from a $800 scanner vs a $$30,000 scanner and just sticking negs in and expecting results to pop out is no more realistic than than expecting your camera to make you a great photographer. It up to the person running the equipment to make it deliver the goods.
I don't know the percentages are but I would guess a large percentage here are doing the Walmart type lab process / scan deal. I would also venture to say the ones running film themselves scan direct on inexpensive scanners with canned generic profiles and the remaining number who run their own film and wet print really only go through the motions without a real understanding of the process. How many of you who wet print ever pull your print from the developer early if it looks like it's coming up too fast and getting too dark? Do you try to force a print if it's too light? Are you tempted to use old developer, outdated film or paper. Is your safe light really safe? Do you know how to test your safelight and paper? Do you settle on one film developer combo or do you skip around and never settle on anything? How many of you can really get everything out of a neg that's in the neg? Dodge, burn, bleach, tone, ever do that? It takes more than putting your film in a can of chemical and shaking it around to be a good lab man and more than sticking a piece of paper under an enlarger to be a good printer. How many here that run their own film ever tweak the process or know the relationship between development, exposure, contrast and density?
I've run my film since I was 9 years old and printed it as well. That makes almost 52 years as a printer. It's more than time doing it, it's understanding what I'm doing and developing a refined technique. When you think about this what's the point in owning great equipment if you let Walmart or the drug store run/ ruin your film and you don't understand how this effects the final result.
you are right on a lot of things here, still I don't think that you need 52 years of experience as a printer to tell whether you like a lens or not.
oh and I'm 21 years old, I don't print (although I have in the past), only develop my film myself and scan it in a cheap canoscan 8800f. does that mean that I don't know what I'm doing and have no idea what I'm talking about? that I can't judge a negative or lens?
I think I can, but what do I know.
but I do get results that are pleasing, not only to myself, and I know HOW to get, repeat and alter them.
I have both and use the non-asph because of it's lighter weight and smaller size. Here's one with m7, provia and summicron asph
I have the 35f2 Asph as well the vI Summicron. I did unload my vII/vIII/vIV' last year as I did not use them enough.
The 35f2 Asph I use when I need "biting" sharpness - edge to edge. The contrast is high so I usually shoot enough with it to "soup" all the films in a low contrast developer - or cut the times in my standard developers. The only lens that rivals the 35f2 Asph is probably the Zeiss Biogon 35f2 as to sharpness - with a slightly more moderate contrast.
The vIV is over rated IMO. It is a good lens, but not extraordinarily good. I am not a "bokeh" chaser so that might explain my rather lukewarm enthusiasm for it. It is not for lack of use = as it was my main 35 for almost 20 years. I found that in many ways the vIII was more pleasing - as is my VC 35f2.5 and my Canon 35f2 LTM.
As stated elsewhere - there is a big difference between scanning and wet-printing. A scan can be manipulated considerably more in terms of contrast and highlight/contrast densities than a fiber based print.
Oh, the vI was kept for sentimental reasons - I have had it for close to 40 years and though not as good as the newer lenses - it kind of fits on an old M2 with TriX - small too and considerably lighter than the Asph version.
A well built, compact performer and my favorite Leica lens.
35/2 asph...
Todd
I'm sure the contrast is crisper than a ver. 1 'cron but I like it.
Todd
Somewhat off topic, but I'll ask anyway... How does the 35 'cron asph compare to the current 50 'cron in terms of sharpness and contrast, in particular at f/2 and f/2.8? I have the 35 'cron IV and the 50 'cron and there's no denying that the 50 is sharper and more contrasty than the 35 at wide apertures. Would the 35 'cron asph be a better match to the 50 at wide apertures?
Cheers
Vincent
I have owned and used both the v4 and the asph; the asph is the best 35/2 lens made. Love the contrast, the tonal range, the bokeh, even the sharpness 🙂 Excellent all round lens, being nice and compact. But to each his own.
Here's one from earlier this week:>
Beautiful tones, tenderly rendered. A great 'case' for the l3ns, as it seems sometimes images do speak better than words, thomasw_ ! I love the 2nd shot, Todd!
Simon I'm glad you have things nailed at such a young age. Now all you have to be concerned about is making great images. If you're pleased with what you get and have achieved your goals then that's what counts.
I guess I'm a slow learner since I feel I'm still learning and growing. At 21 I only had a few credits, Esquire Magazine, UPI, AP and a few other minor publications and didn't really know much, I guess but the older I've gotten the more I realize what I still have to learn. The unfortunate thing is we eventually run out of time.
Todd you have some lovely work both technically and artistically. Your approach is a no BS direct approach that I love. Beautiful vision and mastery of your medium. I always love looking at your images.
My friend had the 35 Cron ASPH and it was brutally sharp, drew with crisp edges and solid contrast. Scans and prints were incredible at any size. It blows away any 35 I've used from Canon (35L) or Nikon (2/35, 1.4/35). No contest, although the EF 35L is damn good. The only lens I know of that is in the same ballpark is the 35 Lux ASPH (I haven't tried the Biogon...). But I would hardly describe it as an ugly lens. It's more 'clinical' than the older 35's, but things like excessive contrast can be tamed in developing, printing or PS.
I have the 35 Lux ASPH and 35 Cron v04. The Cron v04 is very, very sharp down to about f2.8. F2 is a little weak. But don't be fooled by all the talk of romantic rendering. This is not a pasty lens by any means. According to Puts, after f2.8 or so it runs neck to neck with the ASPH.
BUT, it has a very different look. Much creamier and it blooms just ever so slightly around the highlights. I see more depth or three dimensionality in the v04 negs, even compared to the Lux ASPH. It's not a low contrast lens by any means and can produce some punch negs, but it has this low level scatter that sits on top of everything. Sort of like blond girls with peach fuzz. It catches the light and scatters, giving them a glow. I think it was Martine Frank who said that Marilyn had this sort of peach fuzz that made her skin glow.
I never really paid attention to the bokeh of the v04. Probably because I've never noticed anything annoying about it.
One nice thing about the v04 is that the transition from in focus to out of focus is more gradual, than with the 35 Cron ASPH, so it's a little more forgiving for scale focusing.
Overall I think the Cron v04 and a roll of properly developed Tri-X is hard to beat. The extra bit of glow, just makes the prints look more alive to my eyes.
I just wish the construction of the front element was less flimsy. Watch out with the small square hood. It locks in to place and if you're not careful, even when putting it in your bag, it can twist the front element loose. With the hood locked in to place, so it can't rotate, it effects a lot of leverage on the front ring.
My solution to the high contrast of the Cron ASPH or any lens with very high contrast? Use a divided developer like Barry Thornton's 2-bath and you'll see all the tonality you want. Or apply a little nose grease to the front element. Worked for Sternberg.
Cheers
Vincent
The latest 50 cron was my first Leica lens. It was sold after a few months when I got my 35 cron ASPH. Sharp as it was, the 50 cron didn't give me the "pop" in photos like my 35 cron does (wide open).
Excellent summary. The differences between these two lens have had me questioning which one to get for ages. Your response helps fill those gaps.
