39mm LTM to minolta MD
franceluxemburg
First name : J-B
3:15 AM
luxemburg city europe
I just bought a ring that fits inside my CV 39mm LTM for leica M
So i a am able? to use any of my minolta MD with my Hexar RF
Can i hope to have as good definition as using let say my 24 mm
on a minolta md body?
Anyhow the ring was 5 euros....
I want to be able I understand you. If you want to mount an LTM lens on a Minolta SLR body, sure, no problem. You need a 39mm -> M42 adapter, and then a M42 -> MD adapter. This will mount the lens on your Minolta MD-mount body. Of course, you'll have to use stop-down metering, etc.
If you want to use a Minolta MD lens on a Leica M body, then no, unfortunately. About the only types of SLR lenses that readily mount on a Leica M are M42 and T-Mount.
Best Regards,
Bill Mattocks
let me be more precise
Got a hexar body, that a leica m mount,
got a cosina-voigtlander ring adaptor LTM on leica M
Now i have this ring that fits inside the LTM 39mm
All that let me put a minolta md lens on a leica m mount body.
What i do not now : will the focussing be good, that iswith guessing
the distance and stepping down the aperture to avoid being out of focus
The ring exist so i presume it was made because the minolta md lens
works on a LTM body or in my case a leica M body, well a hexar RF....
I would prefer to now before wasting a roll
Many thanks
Many thanks
Sorry, let me try again:
1) Got a hexar body, that a leica m mount
Yes, a Hexar has a Leica M lens mount. It's not EXACTLY the same, but very close.
2) got a cosina-voigtlander ring adaptor LTM on leica M
Yes, I understand that too. Lots of companies make adapters to turn LTM 39 to M.
3) Now i have this ring that fits inside the LTM 39mm
If I understand you correctly, you are saying you have an adapter that goes from your Minolta MD lens to your LTM 39mm body. I have never seen such a thing. I can image one going the other way, but not such as you describe. But I suppose one could be made. If you have one, then the appropriate question is how long is it?
Because the correct distance from the rear flange of the Minolta MD lens to the film plane is 43.50mm, and the correct distance for the Leica M mount lens is 27.95mm, then the adapter MUST BE EXACTLY 43.5mm - 27.95mm = 15.55mm long, no more and no less.
If all this is true, then yes, you can scale-focus your Minolta MD lens on a Leica M-Mount body (the Hexar you mentioned).
There is some controversy even so, because some say the Hexar and the Leica M use very small differences in flange-film distances, and so people tend not to see the lenses as interchangeable. Others have no problems with this.
I hope you find this helpful.
Is this 'ring' you talk about custom-made? Because I can find no record of such a thing existing as a product. There are plenty of adapters to go the other way, from LTM lens to M42 to Minolta MD camera body.
Best Regards,
Bill Mattocks
The ever-reliable SRB Film in the UK quote L39mm - various 35mm adaptors on their website, though not specifically Minolta MD. It is probably possible, but does not look cheap - about the price of a used CV 25mm. 5 euro is a bargain if it works.
thanks for your answer.
the ring has germany written on plus "leimin" no brand name
Weird!
the thicknest of the ring with the ltm on it is +/- 14 mm
So the distance seems to be uncorrect and it is not like a SLR where
you can check the focus throught the finder
thmk said:
Leimin is an adapter for Minolta MD to Novoflex Universal Bellows with 39mm Screw Mount.
Cheers
Thomas-Michael
Now that makes sense! Yes, bellows frequently have 39mm screwmount adapters on both ends, with adapters to mount lenses from different manufacturers on them. Thanks, I would never have thought of that!
And I'm sorry, but the distance is wrong, so I don't think it will work on a Leica M mount camera.
Best Regards,
Bill Mattocks
