3d Printed 6x14 Camera
Hogarth Ferguson
9:15 AM
p6x14camera
I was recently gifted this 6x14 camera. I made a comment on a google plus post about how I'd like a 6x14 camera, and the gentleman emailed me saying he would gladly print me one. It was designed for a 90mm originally, but he redesigned it for my 58mm super angulon, and I love this thing.
58mm+super+angulon
I wrote about it here
Some images from it so far have been really pleasing.
Untitled by Hogarth Ferguson
Awesome! I have been looking for a good reason to hop into 3D printing. And this has just pulled the trigger.
A quick question, what was the printer used for this?
It's not pretty - but the results look good.
Any way to 3D print a helicoid focus mount ?
Print, probably. Make work, not easily, I suspect. Look at the finish! Two rough surfaces are probably going to burr and jam very quickly. I'd look for a helical mount from something else such as an old enlarger; fit the lens into it; and build the camera around that. Or use a bellows: again, taken from an old enlarger or even a scrap camera.
Cut the excess body from the pathfinder body that contains the bellows and front standards, bellows and a half inch of the rear of a Pathfinder 110. Then 3D print a back to stretch out to the 6X14 needed for the rear frame. The frame is wide enough to incorporate 120 film width. One just needs to move a back far enough from the original Pathfinder film plane to accomodate the 14 cm film length. Longer panos could work here.
That way, you have a focusable bellows for varied focal lengths. Every Pathfinder I have come across has had a perfect light tight bellows, a knob on the door for focus, and the camera is foldable. I cut the pathfinder body down to a half inch or so around the door, so just have to create a printable back and affix it to what's left of the Pathfinder. Could do roll film back, like the one shown on this printed body. However the sliding bellows front plane draws me more and the use of varied lens lengths adds flexibility.
I saw someone make an interchangeable lens mount using SLR pieces before about 5 years ago. This was just one of the many FrankenCamera mods I've seen on the Pathfinder body.
Naturally printing the whole camera seems good, but I like this Pathfinder exercise and may proceed. Will post pix of the "cut" pathfinder later today.
I have four of these pathfinder bodies. Could even go fixed lens with varied focal lengths. ????????
One more pathfinder pic with knob for focus.
You can print it using laser scintering printing. Finer grained and you can't see the striations.
But a plastic helical wouldn't hold up well. Get a metal one off of eBay.
Does the 58mm look good in the corners? Fantastic work, btw. Did this guy write the article in Japan Camera Hunter?
Sent from my iPhone using Tapatalk
Sounds good! Keep us posted...
Looking at ordering one made for the lens
I've mentioned I want a helical, but dont want to feel ungrateful. He offered to reprint the front cone for a helical, though.
Yes, same person who wrote it for Japan Camera Hunter. I believe he has printed a 90mm version, a 72mm version, and a 150mm version.
Some fall off, I guess in the corners, but I do not pay much attention to that, honsestly.
Where's the old Ford graveyard at?
Jim B.
I dont remember the town exactly at the moment, but I can find it for you if you'd like.
Alright, it is
1016 Historic Homer Hwy, Homer, GA 30547. I was driving from Atlanta to Asheville and took a back way as I was in no rush to get there.
