My meter was 2 stops off, causing underexposure. So, I decided to adjust it, using the directions at the link given above. My CL matches the camera described at the link.
With the back of the camera taken off, you can see three screws on the bottom plate. Two are near the battery, and the other near the film canister side. Removing the screw on the film canister side allows the bottom plate to lift up (mine sprung up a little ways). That opening created by the plate lifting gave me room to get a thin blade (X-Acto knife) under the edge of the bottom end of the cover-plate. The cover-plate is held in place with contact cement. Carefully working the blade inward and toward the top of the camera, I separated the cover-plate from the body without any damage to either. The cover-plate that I took off is made of thin aluminum, thicker than foil, but pretty thin.
I used cotton swabs, denatured alcohol, and elbow grease to clean off the old contact cement from both the removed cover-plate and the camera body.
I followed the directions given at the link above, and brought the meter into pretty good adjustment. It's not perfect, as the tiniest adjustment to each screw can make a bigger than expected difference, but after about two hours, I had the meter in fairly good agreement with another meter at 1/2 second, 1/60 second, and 1/1000 second.
Then I adjusted the battery check screw, so that the needle centered when checking the battery.
Now I need to buy some contact cement and put the cover-plate back on. EDIT: Done. The cement is drying now.
