6-bit coding Nokton 35mm f/1.2 with M-Coder
AusDLK
Famous Photographer
12:56 AM
Austin, TX
Anyone have success 6-bit coding the Nokton 35mm f/1.2 lens?
I tried it but there is a flange screw in the way...
Seems this would pose a problem for John Milch as well.
I did code it myself with a sharpie. You have to paint the screw head that is under the coding area white for it to work properly.
After that worked I emailed John and the response was it is possible to do, so I sent the mount off to him. I'm waiting to get it back. Should be soon
I had JM mill mine, got it back and coded it as a Summicron per Sean Reid's suggestion. The screw didn't pose a problem. I just covered it with white nail polish.
