90mm summicron f/2 leitz canada
ron klein
6:39 AM
Thinking of purchasing this as a portrait lens for my M8. Im a bit concerned about the wieght. Also, seeems to have a tripod mount attached. Is that standard, or added?
Ron
Yep go to gym train with weights, the lens will feel light eventually.
The tripod mount is standard with the f/2 90mm and f2.8 135mm, if you want to clean the rear surface it is easy to unscrew the whole optic from the focusing mount.
Noel
BillBingham2 said:
Check to see what version. Mine is from the mid 80's and there is no mount. Older 90/2s have a mount but they are much larger. I know that the 90 'cron I have was made in Canada.
B2 (;->
They are heavy as well. you need helium in the Gbag after a few hours.
Noel
Noel
Mine doesn't have a tripod mount either, nor do I need one, easy to handhold. It's big but it's not huge. It's heavier and bigger than any other 90 that I have, but downright diminutive compared to some of my SLR lenses. 🙂
Mine has. E48, Canada, built-in hood, removable head, presumably the
2nd most heavy M lens that Leitz has built (after the 135/2.8). Nice bokeh though.
Glad it has the tripod mount, would hesitate to use the M3 with
that lens on a tripod via baseplate.
Roland.
