ktran
Hi Everyone,
I've recently come across a 9cm black brassed Elmar in very rough shape, and I'm trying to get it taken apart to clean the optics/etc. However, the problem is that I can't even move the aperture ring, nor loosen any of the screws (I fear damaging the heads if I apply too much force).
I suspect everything's just rusted shut, but would welcome any opinions on what/how to try getting things loosened up (general advice on disassembly is also appreciated!)
To-date, I've tried applying a bit of naphtha around the aperture ring, asking a watchmaker acquaintance to use his ultrasonic bath to see if that might work, and finally, with the knowledge that I'll be stripping and cleaning everything anyways, WD-40. So far, nothing has worked, and the aperture ring is still stuck. I've even tried unscrewing the back element out with spanners, but that's stuck too.
I'm tempted to just soak the bloody thing in naphtha, optics and all, but I will listen to Voices of Reason 🙂
Thanks in advance!
Thanks in advance!
