135format
You might be right - I am no fan of LPL enlargers (they tend to fall apart all by themselves.) That however is only my opinion, man. According to Ilford's pdf referenced above, the LPL, along with many other popular enlargers, do not attain 5.0 filtration.
It's not a myth, it's just the way it is.
Ahem, I just took the trouble to look at the referenced Ilford pdf above.
And if you look carefully you find that Kodak filtration goes to 200 and 199M gives grade 5. You don't get that if you are trying to use combined Y+M figures but if you use single filtration then you do. So we now have a Myth that LPL isn't capable when the durst document says it is.
they only show it as G 4 1/2 for Kodak because those figures are provided for contrast changes with NO time change. With single filters there is a time change with each filtration setting. i.e. going from 0Y/150M to 199M would require a time change.
The fact you've tested it to G4.7 just says your particular test/enlarger didn't achieve it and that might be because your enlarger is infact a pile of junk or because your developer wasn't upto it. Again its fairly arbitrary since 4.7 to 5 is such a small difference. But Ilford do say LPL can achieve it.
As per Ilfords caveat, some enlargers only go to 170 kodak units which means you are stuffed. What does LPL goto?
