A new Canonet !
fredus
3:27 PM
San Jose, CA
Hi there,
I'm the new proud owner of a Canonet, picked up on Ebay. Some first obeservations:
- Very nice finish and construction
- Clear viewfinder
- Little disapointment for the patch. Sometime it makes it hard to focus. Maybe I was expected Leica kind of patch
- Extremly quiet shutter !
- A little surprised by the rewind mechanism. Basically, I can rewind between shot. I have to look at the little window to see if it's red or white to verify if the shutter is armed or not. This is a little different ... But I should get use to it pretty fast.
I'll develop the first roll tonight and will post some picture. Hopefully, they'll be good !
Fred
Welcome to the world of Canonets. The wind mechanism should lock so you can't double wind. This is a fairly common fault. If you search the threads, there was a fix just recently so I won't repeat it. You will have to lift the leatherette which on a Canonet is a real ******.
Kim
fredus said:
Hi there,
Fred
I knew there was something wrong 🙂 Oh well, it doesn't really matter since you have the window which is a good indicator. But I'll look into that fix anyway ...
Thanks !
Fred
Thanks for the pictures ! That will come handy !!
One thing I've noticed today that I didn't notice yesterday. When I'm on the 'A' setting, the aperture change when I turn the focusing ring ! Looks like it think that I have a flash on the hot shoe (I've read that if you're using a flash, the aperture will ajust based on your focusing distance ... But in that case, I don't have a flash !!) .. I took perfect picture yesterday on 'A' but didn't notice the behavior ... What's happening ?
Fred
