f16sunshine
Moderator
also AA filter is gone with this mod. When you consider used A7 easy to find for 900 and 400 for MOD, you have something close to M240 for 1300USD
That's pretty damn amazing really! Thanks for the report.
Thanks Charlie - you wouldn't happen to have a ZM 25/2.8 Biogon that you can test, do you? That is one of my favorite lenses, but it fails miserably on my A7R. If the mod shows the same level of improvement as it did for the ZM 18mm (thanks by the way), I'm sold.
Does anyone know what this mod will do to standard FE wide-angle lenses? What will it do to dslr-style, telecentric designs (probably nothing I'd assume).
The FE35 and 55 will be a little less good on a mod body, according to tests with the mod at lens rentals.These lenses were specifically designed for the thick CG.
The new zeiss 35/2 loxia may be better. Most SLR glass should be better. Any lens designed for film should be better.
Since the A7 could not shoot canon AF glass as well as a 5D, I would think alot of newer non-FE glass should do better.
These differences will become more subtle as the film lenses get longer, but they should still show up on a close look.
Apparently the Lux ASPH 50 is way better 🙂
It may do the M9 corrosion thing, but they say they will stand behind it.Very very interesting. I suppose they went with a thicker sensor glass for durability? I hope the thinner glass isn't a liability, though I suppose nothing should ever touch it, ideally.
Based on the tests done at lensrentals, the sacrifice is virtually insignificant, and surely indiscernible.
If I understand it correctly, their test shows a difference of 40 lp/IH wrt corner resolution for the FE 55/1.8, which, in their own words, "might be" significant.
From the lensrental.com blog:
"I should also point out that there is a slight decrease in corner resolution with the modified camera compared to stock. A difference of 20 lp/IH is almost certainly not significant. The difference of 40 lp/IH might be, that's about the range where we see a consistent difference."
I should point out that I shoot quite a bit of landscape images with the A7R and FE 55/1.8 and do make large prints (including metal prints) and for those types of images, corner resolution is important. If I were using this for people or street photos, then I'd be all over this mod.
Granted, they only refer to this as a small sample test, and not intended to be definitive, but it is enough to give me pause. I'm usually a later adopter of new technology anyway, so I will most likely wait for more definitive tests before I buy into this mod.
I have two A7's. I'll send in one and keep the other for native/A-mount lenses. With used A7 bodies consistently going at ~$900, I think a second body might not be a bad idea?
For me the question is whether I should send in the A7S...I use it for low light, mostly when I can't see what's in the corners anyways. But it would be nice to make it AA-less.
