Accident while mixing up Diafine
jrong
Too many cameras
9:23 PM
London, UK
Feeling a bit stupid here. I was mixing up a batch of Diafine.... and mixing solution B with some warm water in my measuring cylinder when I managed to shatter my glass thermometer while using it as a stirrer. I know, bad idea, but it's too late now. :bang: There was a small amount of undissolved solution B powder at the bottom of the cylinder, as well as copious amounts of alcohol and blue dye, and bits of broken glass. I had to chuck out the contents of the cylinder along with the undissolved precipitate at the bottom, maybe about two teaspoons worth.
I have mixed up the rest of the solution B powder, I have just under a quart (~ 960 ml, I think I have approx 950ml) and now I am worried that the proportions aren't quite right, because of my accident with the thermometer. How will this affect my use of this Diafine batch, does anyone know?
Jin
All is not lost
All is not lost
You've learned a good lesson. Don't use your thermometer as a stirrer. It's for measuring temperature. Get a glass stirring rod.
What you have is probably fine, test it and see.
If it is not, Steve Anchell's "The Darkroom Cookbook" gives a "Diafine-type" formula:
Solution A:
Water at 125F/52C 750 ml
Sodium sulfite, anhydrous 35 grams
Hydroquinone 6 grams
Phenidone 0.2 grams
Sodium bisulfite 6 grams
Room temperature water to make 1.0 liter
Solution B:
Sodium sulfite 65 grams
Borax 20 grams
Cold water to make 1.0 literThis solution B will work just fine with proprietary Diafine Part A.
Marty
